Ginding From Front End
Old Nov 21, 2007 | 05:20 AM
LILMAN's Avatar
I've been getting a grinding noise from my front drivers side. It doesnt get faster with acceleration but it gets louder. I want to get an idea of what to look from when I take the wheel off. I'm not getting any abnormal brake dust from this side but my rotor appears to be getting f'ed up. My pads are good from what I can see. My only thought could be the caliper. Any feedback is good.
Old Nov 21, 2007 | 05:34 AM
|Bijan|'s Avatar
UCF Lexus
Hub bearing possibly.
Old Nov 21, 2007 | 05:41 AM
LILMAN's Avatar
Is that the same as the wheel bearing?
Old Nov 21, 2007 | 07:25 AM
|Bijan|'s Avatar
UCF Lexus
yezzir....a PITA to replace yourself if you dont have the right tools.
Does it have a "whaaaaoooh whaaaaoooh" noise?
Old Nov 21, 2007 | 07:31 AM
LILMAN's Avatar
After reading the stickies. How do I know which bearing I need(inner/outer), or would I have to find out after I inspect the hub itself. I like to have everything I need before I tear stuff apart. Also I see different prices http://www.napaonline.com/MasterPage...heel&VehCode=Y but the parts look the same. Me and any other person would get the cheapest one. Is there a difference?
Old Nov 21, 2007 | 09:00 AM
emoore924's Avatar
Quick check for wheel bearing problems:
Raise corner of car
Chock wheels (safety you know)
Make sure tranny is in neutral so wheel spins freely
Grasp tire at top and bottom and rock in and out firmly -- push in at the top whilst pulling out at the bottom, then visa-versa.
If you feel a "clunk clunk" as you push-pull at the top and bottom, it is likely that the wheel bearing is loose, and may need adjustment or possibly replacement.
Old Nov 21, 2007 | 12:55 PM
LILMAN's Avatar
How the hell am I suppsed to get that hub off the contraption the guy uses on Motorcate is something he made in his garage.
Old Nov 27, 2007 | 06:43 PM
vilmaxima's Avatar
sounds like the hub bearing...but if u said your rotor is getting f****d up, it might be those 2 bolts that hold your caliper, to the caliper bracket, I have had a couple of those get stuck, they are supposed to move in and out(the 2 bolts with rubber around it) I had these lock on me a couple of times, helped me, hope it helps u.
Old Nov 28, 2007 | 06:37 AM
LILMAN's Avatar
Got it taken care of. The damn how to's make everything look easy. I ended up takin it to a shop and having them swap out the bearing. They only charged me $60. Rides on clouds now. Do I have to get another alignement though?
Old Nov 28, 2007 | 07:30 AM
aporozco's Avatar
Stock Airbox Supporter #3
yea good thing you got it done. mine were bad and my damn tire fell off the next day. costing me $275 but i got a deal
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
GregL65
Sep 5, 2015 09:37 PM
jfl330
Sep 4, 2015 01:44 PM
