thats what i thought. does anyone know the production date on a 96 that the ecu needs to be for JWT to mod it?
I called jwt and they told me that a 96 ecu will work fine in my 97 without throwing a cel but I did not ask about cali and fed spec
guess your wondering if you should get that ecu also
Quote:
JWT confimed this to. they said if it was a CALI spec then it would trip an ECU.Originally Posted by kzoosho
I dont know. If you search i havent heard of any one using it without the cel.
So I could use any 96 FED spec ECU in my 97 SE 5spd? Im having problems with production dates and searching for it on car-part.com - does any one know this info?
i found this ECU for a 96 - A18-C84-EX8
What JWT said about it:
A18-C84 EX8 / 96 Maxima 5spd / U / OBD2 / A32-VQ30DE / 23710-54U03
they told me that it would work but couldnt garuantee that it wouldnt make a CEL light go on. apparently the "U" means it will work in both a FED and a Cali car....i just want to know if I dont mod it with JWT and just plug it into my 97 5spd SE it wont set off a CEL.
Quote:
http://forums.maxima.org/showthread....&highlight=ecu
are you talking about me shorting out my stock ECU....yeah that sucks and me = moron!Originally Posted by KRRZ350
Not that it matters for you now
so if a fed spec 5spd ecu doesnt cause a code in a 97 fed spec 5spd why is there a link to this:
96 ECU in a 98 - getting rid of P0136
http://forums.maxima.org/showthread.php?t=260209
I believe it will throw a rear O2 code due to the difference in 3/4 wire O2's. Wont be receiving the proper reference. Just follow what the link has and you should be fine.
Quote:
dont you have to dino alot to make the emanage work? all i need is something to cut off the rev limiter cause i just installed an 00vi.Originally Posted by kzoosho
I dont know . I would just get emanage and call it a day lol
