What The Hell
Old Dec 9, 2007 | 11:33 AM
tc97max's Avatar
What The Hell
I am removing my Knock Sensor and I have done the hard part, i got it out from under the manifold but I cant get the damn sensor out of the harness its not the snap on and off kind like all the other plugs on the car what is the god damn trick. there is a little metal poll that runs along the outside that stops it from comming out what do I do?
Old Dec 9, 2007 | 12:12 PM
QNO_A32's Avatar
yeah that can be frustrating...you will see that little piece of metal it looks like a staple..that will need to be taken out with a little pick or a hook will do it.do not lose it ,slide it back in after new sensor is on the harness and your good.
Old Dec 9, 2007 | 12:13 PM
tc97max's Avatar
thanks I figured it out.
Old Dec 9, 2007 | 01:32 PM
tc97max's Avatar
And WOW am I glad that I replaced that ****er. Now I have power below 3grand!
Old Dec 9, 2007 | 03:23 PM
ROCKART's Avatar
wants an I35
welcome to the brotherhood.
Old Dec 9, 2007 | 09:15 PM
max ride 41's Avatar
power below 3 grand i did NOT get after replacing the knock sensor. i don't think it did $hit to be honest. i think my trans is goin out, its slow to shift going up hills. any ideas people??? sorry about the thred theft, i need some help with this. thanks to anyone in advance.....
Old Dec 9, 2007 | 09:22 PM
Qbridg3's Avatar
It's a stringy lil ****er isn't it. Without it the car runs like ****.
Old Dec 9, 2007 | 09:26 PM
96blackmaxSE's Avatar
boost me.....
ahahahhahahaha....count me in.
Old Dec 9, 2007 | 09:43 PM
boost me.....
Old Dec 10, 2007 | 09:37 AM
Double E's Avatar
Max ride,
I'm assuming you're running 93 octane, have done an injector cleaning & the TB & IAC is clean... Power returning from a KS change will only really be felt if you are also using the highest octane you can find....even then, it may take a couple of week of routine driving. (yeah...you might want to start a new thread with all the details.)
A last thing to look at is adjusting the throttle positioning sensor.
Old Dec 10, 2007 | 09:49 AM
slow97maxima's Avatar
member
Originally Posted by Double E
Max ride,
Well i had the knock sensor code for about a year, have always run the lowest octance. decided to change the little f*ck yesterday and it pulls a lot harder.... still with 87 octane. like its rediculous...the tires havent broken loose on dry pavement for the past year until now
Old Dec 11, 2007 | 05:26 AM
Double E's Avatar
Good job changin that KS!! (listening Max Ride?)
Do the other stuff mentioned and THEN run the good gas for the rest of your ownership with the car and you'll have little to worry about.
Old Dec 11, 2007 | 10:48 AM
93altima's Avatar
Turbo 4th Gen
my 95 threw that knock sensor code at me the other day i had to change an injector i got it deleted now the light went out what yall think??? will it come back
Old Dec 13, 2007 | 06:08 AM
Double E's Avatar
Yes.
Old Dec 13, 2007 | 07:16 AM
19Maximus98's Avatar
If you continue to use $h***y gas it will probably throw the code again. At least that has been my experience.
Cotozic
Jun 28, 2017 08:01 PM
RealityCheck
Oct 2, 2015 06:34 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
