Whose got the highest mileage?? Any issues?
#121
518,xxxx (kms) :D
322,xxx miles. Sucks I just type up a whole post of what I've changed & what's original & it timed out...
Anyway, here's the condensed version:
- rebuilt tranny ( bearing pre-load issue)
- 2 x starter
- 2 x alternators
- water pump
- 2x timing chain tensiones
- cv shaft ( ripped boot killed it)
- 1 injector, another one going
- swapped in slightly used eibach/Illuminas couple of yrs ago
- cheap paint job (had a minor altercation with a guardrail one winter that damaged my front bumper) Suffice to say winter tires are now the norm.
- have the new clutch master cylinder in trunk ready to install (over a year now)
Original:
CLUTCH
wheel bearings
rotors!
Rust..coming back...wheel & hood lip
- 2 x starter
- 2 x alternators
- water pump
Original:
CLUTCH
wheel bearings
rotors!
#123
97 max autotragic car has 134000 on it (motor ~70000)
when I got the car it had 115000
parts replaced:
knock sensor
rear calipers
All rotors
rack and pinion
AC compressor
Fuel Filter
Wheel Bearing (Right Front)
Catalytic Converter Hanger
Motor Mount
MAP/BARO Switch Solenoid sensor
O2 sensor (rear after cat)
The above tend to happen if you buy an old used car. Thats why never buy old cars
parts replaced:
knock sensor
rear calipers
All rotors
rack and pinion
AC compressor
Fuel Filter
Motor Mount
#127
96 5mt SE
miles = Exempt on title (somewhere over 250,000 i guess)
Had it only a few months and changed....
motor mounts, clutch, drivers seat, water pump, L/R cv, struts, springs, rear bumper, sunroof, all leather boots and um... :::sigh::: soon to be my wife
#128
98 SE 5 speed, 169000 miles, purchased from original owner 3 years ago...
Replaced (over course of 66,000 miles):
-Rear rotors
-Replaced worn brakes with Hawk brakes pads front and rear
-Clutch line
-FL Half-shaft and boot (due to old boot being cracked)
-Thermostat/coolant flush
Plus many other preventative maintenance items, luckily no CELs so far. Currently dealing with noisy fuel injectors (sounds like tick, tick, tick). One is bad in particular. Probably will send all 6 in to be cleaned (~$17ea). I'm very happy with the car, hope to keep it as long as I can (or until I have enough cash to buy a newer VQ powered beast).
-Rear rotors
-Clutch line
#133
#135
179k 97 nissan maxima gle
*new rear right window
*new ecu or get it checked cuz it would beep when the car is pushed to hard
*engine light comes on and off randomly
*need a new radio asap
*speakers seem to be f***ed cuz my driver side one works
*need to fix the frame
and thats all i could think of
#138
128,XXX Miles w/ a few problems
just bought my 96 SE last friday 4AT with 128,XXX...
the guy i bought it from said it had just gotten new brakes AND rotors, Thats a lie beacuse theyre all grinding again so brakes and rotors are goin on tuesday.
Rebuilt Tranny
Tune Up (including O2 Sensors/Knock Sensors and some other stuff)
Stuff i KNOW i need ASAP:
AC Compressor
Power Steering Pump
Suspension (Might as well switch for Tokico Illuminas/Tein S-Tech Combo)
4 Rotors
Driver side Front Axle
Muffler (stupid Ricer muffler has to go...killing my backpressure)
I Guess once these Beauties hit 100+, Regular RELIGIOUS maintenance is a MUST
I Still Love My Maxima Tho.
Rebuilt Tranny
AC Compressor
Power Steering Pump
4 Rotors
#140
JUST GOES TO SHOW HOW RELIABLE THESE MAXAMAS ARE...LAST YEAR I BOUGHT A PARTS CAR FOR $ 600..LEATHER WAS PERFECT,CAR WAS IN THE LADIES BACKYARD FOR 2 YEARS WITH THE HOOD WIDE OPEN.I PUT A BATT. IN THE CAR AND ON THE FIRST TRY IT STARTED RIGHT UP (TOTALLY RUSTED OUT UNDER THE HOOD 290,OOO MILES) GOTTA LOVE EM
#141
Rebuilt Tranny
AC Compressor
Power Steering Pump
4 Rotors
Rebuilt Tranny
AC Compressor
Power Steering Pump
4 Rotors
Could you tell me how much did it run you to rebuild your 4AT ?
And also who did the job ? Dealer, local mechanic etc. ?
#144
guess ill throw mine up as well.
1996 - SE Auto 158K
purchased 4/05 with 122K
3 wheel bearings/stock one is front passenger.
trans flush
1 windshield due to F@#$ing semi's around the rural areas and working on another crack now due to same problem. . .
brakes, and rebuilt rear calipers
tires, Bridgestone Potenza G009
Starter, i know this was the second because the on i removed was an AZ Duralast
Power Steering pump
Valve cover gaskets
Water Pump
Spark Plugs, Oil etc. . .
1997 - SE 5SP 212K
Bought 10/08 with 211K
This is my project. Many mods to come when resources appear!
Plugs and Oil. not the dail driver, so no concern for anything. although front core support is rusying out, and front 2 tires are shot and needs an alignment BAD
Hell, might as well throw my dads up here too.
1999 - GXE Auto ~70K
Bought 8/03 with 8K (he got this thing for a STEAL)
Trans Flush
Oil
Plugs
Bank 1 O2 sensor #2 twice. code still wont go away.
Codes P138 & P139. Any Suggestions?
Had a 1991 SE with 217K when we sold it. still kicking myself for selling the old girl. o well
1996 - SE Auto 158K
trans flush
Power Steering pump
Valve cover gaskets
Water Pump
1997 - SE 5SP 212K
Trans Flush
Oil
Plugs
#147
um.. Just got mine. Has 205000. Still have yet to drive it more than around the block though. Serious exhaust issues, 8 CEL codes, no power to fuel pump, short through shifter adjusted ALL the way down so it rubs on the cat convertor, front pass strut loose at the hat, neither radiator fan turns on, no heat.. Um.. Other than that, it's GREAT....(<---sarcasm).
But, heck, I got it for free....
Len
Len
#149
96 Max with 220k KM (I don't know what is in miles)
repairs made last year to today:
-Wipers linkage
-Knock sensor
-Air intake temperature sensor
-Top plate front right
-Power steering pump
-Heating thermostat
-Y-pipe
-Muffler
-Catback
-Radiator? (sorry correct me if we can't say that in english )
-Wipers linkage
-Knock sensor
-Heating thermostat
-Y-pipe
-Muffler
-Catback
#150
98 i30t with 157k.
Starter
Alternator
KS
New tranny at 60k (on the dealer)
2 resonators & 3 mufflers (lived most of it's life in Cleveland)
G35 sport wheels (again because of harsh Cleveland weather)
Front Calipers & Rotors (last week)
Axles (next week)
A33 muffler (week after next)
Y-pipe & O2 sensors (next month)
Shift Solenoids (month after next)
Runs like a top. Mostly maintenance items. A lot of things were due to driving conditions which ultimately, corrosion will be her demise.
Starter
Alternator
KS
Axles (next week)
#151
Did you blow 2 manual trannys? If so give it up, drive an auto or do the auto/manual mod.
#154
#155
Originally Posted by Phatmax98
Guess I spoke too soon...my ses light just came on in the past couple days...now I gotta replace the KS and rear 02 sensor...182k on the od
#157
219K miles right now on my '96 SE! The car has had a new timing belt & tensioner, water pump, clutch, and alternator & starter changed. Everything else has been basic maintenance and it is still running very strong! As far as mods go, it only has a Warpspeed Y-Pipe and a glasspack in-place of the stock rusted out muffler (I went cheap but it sounds good )
