tranny going bad ?
Old Dec 12, 2007 | 12:06 PM
xkazik's Avatar
tranny going bad ?
sometimes when I'm switching from first to second on higher rpm i feel like it grinding a little . anyone faced this problem ?
Old Dec 12, 2007 | 12:39 PM
ghrycan's Avatar
my 98 max has that problem too, but at mid range rpms, and especially when gearing down from third to second. sometimes when it's colder, i can't even gear down into second, cause i just cant get it in. i took it to the mechanic, and he said that the clutch was fine, and that reverse usually goes before anything if your tranny has problems... so i'm kinda facing the same issue as you
Old Dec 12, 2007 | 12:46 PM
kzoosho's Avatar
Are you a 5sp or auto?
Old Dec 12, 2007 | 01:03 PM
xkazik's Avatar
its a 97 se 5 sp . and yea same here the problem gets worse when its cold
Old Dec 12, 2007 | 01:05 PM
xlr8r's Avatar
If you've recently had the tranny oil changed and didn't replace with GL-4 oil, that would make it hard to shift.
Old Dec 12, 2007 | 01:07 PM
xkazik's Avatar
hmm right before i bought the car the guy said he changed the oil , but i dont know what he put in it. what oil should i buy? any how much of it do i need ?
Old Dec 12, 2007 | 01:11 PM
kzoosho's Avatar
U know what i dont think i have gl4 oil in my 2001 vlsd tranny. Its real stiff in the morining when cold. What are the side affects of not running the gl4?
Old Dec 12, 2007 | 02:36 PM
rcintorino's Avatar
Is it really GL4 that goes into the tranny? I've had a few manuals now that require dextron atf. I know older trannys and truck trannys take gl4.
definately check the oil level if you're having hard shifts when it's cold. also, try the throwout bearing. I was having hard shifts in my s10, and a little grinding into second from either angle (upshift or downshift). replacing the throwout bearing solved the problem.
Old Dec 12, 2007 | 03:59 PM
Yes, our 5 speed trannys do indeed call for GL-4.
Old Dec 12, 2007 | 04:56 PM
TunerMaxima3000's Avatar
All depends on the transmission, you use what it calls for, nothing else.
Old Dec 12, 2007 | 05:00 PM
MorpheusZero's Avatar
Hit up Talkinghorse (Ed) for some Amsoil GL4 full synthetic. Great guy to deal with plus better shifting.
Old Dec 12, 2007 | 06:14 PM
xkazik's Avatar
On my way to order some Amsoil =) never knew oil can make a big difference but i guess it does hehe just have to wait to see
Old Dec 12, 2007 | 07:31 PM
That's what I told him via PM as well.
Old Dec 12, 2007 | 07:40 PM
cefiro80's Avatar
Old Dec 13, 2007 | 10:01 AM
MaxFanatik's Avatar
i had this issue for 3rd, i put in mt-90 man my tranny is smooth as **** now!!!!!! do a tranny flush and put redline mt-90.
Old Dec 15, 2007 | 01:10 PM
xkazik's Avatar
just replaced mine with Amsoil GL4 full synthetic.. BIg difference.. so far no griding noise from second gear =) yey
chisam14
Nov 6, 2018 08:56 PM
fx4five
Oct 18, 2015 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
Andy29
Sep 29, 2015 05:32 AM
