how do u open the heated switch
Old 12-12-2007, 05:47 PM
maxx0831's Avatar
Ok guys, how do u open the heated switch. Im trying to change the bulb inside, but i dont know where to start. I trying not to break it
maxx0831 is offline
Old 12-12-2007, 05:59 PM
19Maximus98's Avatar
what kind of question is this?? How about first telling us what "heated" switch you are refering to. Then maybe someone can answer.
19Maximus98 is offline
Old 12-12-2007, 06:08 PM
maxx0831's Avatar
oh my fault i jus got it open, i was tlaking abt the driver side heated switch for the driver seat. I jus wana kno wut bulb fits in it.
maxx0831 is offline
Old 12-12-2007, 06:17 PM
shissqbob's Avatar
that would be an led. i believe they would be specifically sold through the dealership IF they're still made. They are freaky looking. The other option is you can put your own in by wrapping each LED lead around each prong.
shissqbob is offline
Old 12-12-2007, 06:22 PM
maxx0831's Avatar
Would that work out alright, or would i have to use a resistor as well
maxx0831 is offline
Old 12-12-2007, 06:38 PM
TunerMaxima3000's Avatar
http://forums.maxima.org/showthread.php?t=546744
read that
and yes you do need to put in a resistor if you change the bulb to an LED.
TunerMaxima3000 is offline
Old 12-12-2007, 06:47 PM
maxx0831's Avatar
thank you
maxx0831 is offline
Old 12-12-2007, 08:43 PM
wanaMax's Avatar
can you still just change the bulb out with an OEM bulb from the dealership. I would think that would be cheaper and easier for me. I don't like the technical electric stuff....even if people think it not hard.
wanaMax is offline
Old 12-13-2007, 03:48 AM
jacobmh's Avatar
If you can get one sure.
jacobmh is offline
Old 12-13-2007, 08:23 AM
Curt Deiner's Avatar
I just changed mine...actually got a used switch from .org member, but the seat picture was worn off. So I took the base of his and the top of mine too make a good one. With the switch at room temp, hold the base of the switch in a vise, insert a flat screw driver to lift the body latch over the snap on one side then the other. Go easy not to break it. It is a 12v bulb, very small.
Curt Deiner is offline
Old 12-13-2007, 11:55 AM
tunermaxima3000:
read that
some nice gentleman listed the radioshack #'s.
and IIRC you will need to buy the whole switch from Nissan to get the bulb.
Old 12-13-2007, 02:17 PM
maxx0831's Avatar
alright guys, i went today to get the bulb from radioshack. I gave the guy the PN dat was shown on this thread, wen he typed it in, he said radioshack discontiuned them and they dont make them anymore. So whats next.. is there any other bulb that can fit. Im thinking of finding a regular 12 volt bulb similar to that and jus wrap it around the prongs
maxx0831 is offline
Old 12-13-2007, 02:42 PM
I'd find out from radioshack what they referred to it as, etc. all the info you can get.
I'd also check with nissan, you never know, they may be able to get it.
Junkyards also are a good bet.
IMO it'd be easier to put LED's in.
Old 12-13-2007, 02:45 PM
its an incandecent 12V, not an LED FYI
Old 12-13-2007, 02:47 PM
and maxx0831 :
there is no reason that you had to start a new thread on this.
Old 12-13-2007, 02:53 PM
maxx0831's Avatar
and maxx0831 :
Yea I kno, I realized that now. I apologize to everyone out there for this.
maxx0831 is offline
Old 12-13-2007, 02:56 PM
maxx0831's Avatar
http://www.radioshack.com/product/in...ductId=2104023
I know it takes 12v but wut does the mA mean.
maxx0831 is offline
Old 12-13-2007, 03:56 PM
milliamps
and its obiously not discontinued, maybe just at that store.
Old 12-13-2007, 04:55 PM
maxx0831's Avatar
milliamps
SO that should work just find right?
maxx0831 is offline
Old 12-13-2007, 05:06 PM
^should yeah.
Old 12-14-2007, 06:37 PM
Nopike's Avatar
Got the lamps from Radio Shack tonight part# 272-1092 about $1.50 for two of them. No soldering required, a little care and patience and it's easy to change. Now good as new.
Nopike is offline
Old 12-14-2007, 11:02 PM
maxx0831's Avatar
oh yes, good lookin out, went today to get the other ones posted, didnt work at all. So tomorrow ima get the ones u posted
maxx0831 is offline
Old 12-16-2007, 12:19 AM
wanaMax's Avatar
would that be the same bulb for the defrost and hazard buttons>?
wanaMax is offline
Old 12-16-2007, 10:50 AM
Nopike's Avatar
. Don't know, if I had to guess I would say yes. You are only out $1.50 if they are wrong.
Nopike is offline
Old 12-16-2007, 10:55 AM
Nopike's Avatar
When you take the switch apart there will be two parts to the switch one part will probably kind of fall out. Make sure you put it back together correctly, a bit of a pain, but if you are careful should be no problem.
Nopike is offline
Miket2006
03-01-2021 03:55 AM
AaronL
08-08-2020 10:31 AM
howardis
12-11-2019 06:10 PM
Fbana41
08-29-2016 12:18 PM
HerpDerp1919
09-29-2015 02:02 PM
Quick Reply: how do u open the heated switch
