Squeaking Sound From Engine Bay
Old Dec 13, 2007 | 04:50 PM
97MaximaSE97's Avatar
For some reason when the engine is cold (starting it up for the first time) there is a squeaking noise comming from the left side of the engine bay. It's not a constant squeak like SQUEEEEEEEEEEEEEEEEEEEEK it's a series of short squeaks until the engine is warm then it goes away. This only happens when the engine is cold, any ideas on what this could be?
Old Dec 13, 2007 | 04:53 PM
heynow's Avatar
Belt?
Old Dec 13, 2007 | 04:54 PM
ROCKART's Avatar
wants an I35
belt.
Old Dec 13, 2007 | 05:46 PM
Hmm I had my AC and Alternator belt done almost 2 years ago/ maybe 10,000miles on them. Do they wear out that quick?
Old Dec 13, 2007 | 08:32 PM
vajguy's Avatar
Your belt might be loose.
Old Dec 14, 2007 | 05:29 AM
heynow's Avatar
it might need to be tightened
Old Dec 15, 2007 | 11:48 PM
vilmaxima's Avatar
check er out for signs of wear and tear.
Old Dec 16, 2007 | 05:46 PM
nismos14's Avatar
§è~® f®ÈÄk
Most likely belts were not installed properly, low quality belts were used or it's just a loose or overtight belt.
Old Dec 16, 2007 | 07:12 PM
alcatranz518's Avatar
A/C Clutch bearing is bad. Search, another member did a writeup on how to. I have the same issue. Belts are new and in good tension, yet when cold will squeal like something is dying under there. Although if you used cheap belts, they lose tension and grip quick. Check tension 1st like was mentioned earlier.
Old Dec 16, 2007 | 09:21 PM
Divewjason's Avatar
It is probably the belt. I think the other members have covered this thoroughly. I do want to add this though: Don't mess with that belt unless you know what you are doing.(It's a given but some people don't realize that even simple things can mess up a car or at least a car part.)
Old Jan 12, 2008 | 09:22 PM
rm4628's Avatar
CLICK CLACK 1
I agree check belts and tension!!
Old Jan 13, 2008 | 05:15 AM
max ride 41's Avatar
ummmmmmmm, EEEEECCCHHHHOOOOOOOOO.....
Old Jan 13, 2008 | 12:48 PM
aznsap's Avatar
i'd say belts. when you say left side, do you mean passenger side?
Old Jan 13, 2008 | 02:19 PM
Snypa's Avatar
belts tension fo sho.
97_GXE
Sep 15, 2015 06:47 AM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
SusieQQ
Sep 9, 2015 12:14 PM
TheMafia
Sep 4, 2015 08:26 AM
