what in the hell is this????????
Old Dec 14, 2007 | 02:05 PM
jvckustumz's Avatar
it was located in between my battery and my eadlight in the relay box, it is a 3 prong connector and i do believe it is fried lol heres some pics...
Old Dec 14, 2007 | 02:09 PM
jvckustumz's Avatar
oh and i don't have any unusual codes, just my o2 sensor, and my iat sensor...
Old Dec 14, 2007 | 03:59 PM
f550maranello2's Avatar
its a relay...
Old Dec 14, 2007 | 04:06 PM
vqmaxman's Avatar
The relay box will have all the listing of what it is,that's if the words are not fading. From whatever spot It came out of it should have a listing for it.
Old Dec 14, 2007 | 06:25 PM
Nopike's Avatar
Whatever circuit that relay controls may have a problem. That could be why it burned out. Could be cooling fans, horn or cruise control. That is why you don't notice a problem........ yet. It is also possible the the relay just failed and a replacement may fix your problem.
Old Dec 15, 2007 | 08:59 AM
jvckustumz's Avatar
well my relay box is broken and i don't know what it is to... is there any way any of you could look at your relay box and tell me? i think it is the ascd relay or the inhibitor relay (thanks to fsm lol) but all my relays are mixed up b/c the box they go in was all busted up
Old Dec 15, 2007 | 09:16 AM
Nopike's Avatar
The grey one, only grey relay in there, is for the inhibit/clutch interlock. If that is the case the car should not start with out it. Do your horn or cooling fans work?
Old Dec 15, 2007 | 10:20 AM
nismos14's Avatar
§è~® f®ÈÄk
Isn't there one like that for the turn signals?
Old Dec 15, 2007 | 11:37 AM
jvckustumz's Avatar
i havn't tried yet, the car started just fine the other day but it has been parked for about a week b/c my o/d would not turn on, so for a week i have been cleaning the egr tb iacv ect and replacing plugs and oil change and tranny and radiator flush then i was swapping out battery's with an optima and i smelled some thing funny and noticed the relay was all melted, the weird part is the day i smelled it the car had not been started all day and i didn't even have a battery in it. i think it is the inhibitor relay however i thought that just controlled the cruise???????
Old Dec 15, 2007 | 11:52 AM
Nopike's Avatar
Weird, I only saw one grey relay in the relay box by the battery and that was for the inhibit relay. What you are holding is not it. What you are holding only has three prongs it looks like maybe a horn relay, or some kind of relay for a light. Other then the horn relay (mine is black?) it does not look like any of the relays in that box. Do your horn or headlights work properly?
Old Dec 15, 2007 | 11:55 AM
Nopike's Avatar
I think ASCD is for cruise and inhibit is for clutch or P or N with Auto trans.
Old Dec 15, 2007 | 12:03 PM
Nopike's Avatar
Try some functions such as turn signals, power seats, windows, sunroof?
I'll take a closer look this afternoon.
Old Dec 15, 2007 | 03:45 PM
Nopike's Avatar
I think it's the horn relay, for some reason mine is black not gray. Bet your horn does not work. The coil probably failed, you can probably just install a new one without worry. You may be able to pull one from the other relay box under the hood if you need to do some testing.
Old Dec 15, 2007 | 04:41 PM
preludexl's Avatar
I cant seem to get images inserted. but hope this helps.
http://img.villagephotos.com/p/2005-1/928692/relay.jpg
Old Dec 17, 2007 | 07:19 AM
jvckustumz's Avatar
is that the relay box in between the battery and headlight or the one on the pass. side fender next to the p/s reservoir? this relay is on the one inbetween the headlight and batt.
Old Dec 17, 2007 | 07:32 AM
Nopike's Avatar
It is the relay box in between the battery and headlight.
Old Dec 17, 2007 | 07:33 AM
Nopike's Avatar
It is NOT the relay box in between the battery and headlight. Sorry. Have you tried your horn?
Old Dec 17, 2007 | 07:57 AM
jvckustumz's Avatar
i think it may be the turn signal relay, i called oreillys and they described the turn signal relay like my bad one, they are delivering it to me at my shop around 10:30 so that may be all it is!!
Old Dec 18, 2007 | 05:18 PM
jvckustumz's Avatar
well my car starts and runs fine however the tranny will not go into o/d, the horn t/s, lights and everything works just like always, the only thing i havn't tried is my cruise control. and i have an auto tranny so it woud be for the P and N
Old Dec 18, 2007 | 07:10 PM
Nopike's Avatar
Weird, I looked in that relay box by the battery and did not see a grey relay like that. Mind you it's cold in my garage so I'm doing this quickly. If you tell me the color of wires running to the relay maybe I can find it in wiring diagrams.
Old Dec 18, 2007 | 07:12 PM
Nopike's Avatar
Cooling fans work?
Old Dec 19, 2007 | 07:00 AM
jvckustumz's Avatar
Originally Posted by Nopike
Cooling fans work?
ya they work, thank you for going through the trouble, the wire colors are green with a white stripe and a solid green and a green with a black stripe
Old Dec 19, 2007 | 04:03 PM
Nopike's Avatar
This is the horn relay wiring. Green w/Blk stripe goes from coil of horn relay to horn Fuse #64 (10Amp). Green w/Wht strip goes other side of horn relay coil to horn switch and theft system. Solid Green wire provides 12VDC from the battery to both horns when horn switch or theft system activates the horn relay. Somebody been playing with the wiring? These wires are not used for any other circuits.
Old Dec 19, 2007 | 04:09 PM
Nopike's Avatar
This information is from 1998 FSM but I would expect all 4th Gen to be the same.
Old Dec 20, 2007 | 08:02 AM
jvckustumz's Avatar
the wierd thing is my horn still works i dunno, everything seems to work accordingly so ill just get a horn relay and see if it fits lol, but it does sound right about the horn b/c for along time after i got my momo steering wheel, i thought the horn wire was a ground for the cruise and it was grounded out for about 6 months lol, i had to unplug my horns tho b/c they kept going off lol, all that is fixed now tho
Old Dec 22, 2007 | 12:57 PM
jvckustumz's Avatar
its the horn 1 relay, a part even nissan has to have on special order lol
Old Dec 22, 2007 | 03:37 PM
Nopike's Avatar
So only one of your horns was working?
Cotozic
Jun 28, 2017 08:01 PM
RealityCheck
Oct 2, 2015 06:34 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
