Cold Start Stall
Old Dec 16, 2007 | 01:30 PM
apeg's Avatar
Cold Start Stall
Just need a little confirmation on this one, I had this same problem a couple years back but just can’t remember exactly what I did to fix it
Happening on COLD days… when I start the car I will stall right away, unless I give it some gas and keep the RPM’s up. After a couple seconds if I let go of the gas everything is fine.
This isn’t the “5-10 sec to start” problem a lot of other people are having, its starts right away but stalls.
Now I did this fix almost 5 years ago now, if I am not mistaken isn’t the problem the TPS? throttle position sensor, I think I took it out & cleaned it to solve the problem.
Can you guys confirm I am barking up the right tree? I hate doing work on my car when its this cold out so I want to make sure I got it right.
Thanx
-aPeG
Old Dec 16, 2007 | 01:32 PM
matty's Avatar
When was your last tune up ?
Clean your TB and your IACV and that should cure the problem
-matt
Old Dec 16, 2007 | 10:47 PM
Snypa's Avatar
im currently having that problem too, and now that FL is 57 degrees now, i kno tommorow im supegonna experience it.
Old Dec 17, 2007 | 08:24 AM
JtzMax's Avatar
Whatchyou say?
had the same problem ... till this weekend and i did just as Matt suggested you do ... clean the TB and IACV. took me under 2 minutes and this a.m. when i started .... no gas at all needed! first time in a long time that has happened.
shut up ... Fl is 57º bloddy hell mate ... it's 19º here in Springfield, Missouri!
Old Dec 17, 2007 | 08:56 AM
black_maxed95's Avatar
16º in wisconsin...i dont feel bad for you in florida...57 is nice out.
Old Dec 20, 2007 | 01:46 PM
hoss805's Avatar
need help
got the same problem
where are the TB and the IACV located
Old Dec 21, 2007 | 01:30 PM
Keep'emclean's Avatar
EricJ
I am having the same problem ... but TB was just cleaned 2 or 3 years ago at dealership. Not sure if IACV was though. (Before I owned the car) I am thinking it may be the Temerature sensor. Did you check that. I heard of other people having this problem and the replacing tthe temperature sensor fixed the problem. Mine only does it when cold .. starts then stalls starts then stalls ... until i lightly press on the gas when cranking.
Old Dec 21, 2007 | 01:33 PM
EricJ
P.S. the reason I suggest the temperature sensor is because it tells your ecu when to adjust idle speed, mixture etc. for cold weather starting.
Old Dec 21, 2007 | 04:17 PM
andrei3333's Avatar
had that happen to me last year, i did lots of work on the car since then and it has not happen yet this year ( it started happening in october of last year, and its already december )
just give her some gas and she'll be fine
Old Dec 21, 2007 | 07:51 PM
gonjdevils's Avatar
Originally Posted by hoss805
need help
or at least clarify what TB and IACV stand for
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
tardrex
Sep 11, 2015 07:35 PM
trungg86
Sep 4, 2015 04:58 AM
