PLEASE HELP , quick question !
Old Dec 17, 2007 | 12:45 PM
rome06's Avatar
my friend has a 99' SE 5spd and it broke down on him a couple weeks ago. Took it to nissan they said the ecu and the wire harness are fried. Now he has a ready to drop in vq35 but my question is since the wire harness and ecu both need to be replaced can we use any 4th gen year harness and ecu, or since his car is a 99', do we strictly need to replace it with another 99' ecu and harness? Thanks !
Old Dec 17, 2007 | 12:55 PM
black_maxed95's Avatar
if you are putting in a vq35 you need a vq35 ecu and wiring harness
Old Dec 17, 2007 | 12:56 PM
JtzMax's Avatar
Whatchyou say?
IIRC you will need a harnes for a 3.5 not the 3.0 .... never done one so I don't know for sure ... but serch, you'll find it.
btw: how the hell did he fry the ECU and harnes? fire ????
Old Dec 17, 2007 | 01:13 PM
adriena's Avatar
i'm the friend hes talking about. we put a z32 maf on it and they said that wiring job may have fried it. we followed the wireing diagram to a t never touch any wires together either so i'm not really sure. but nissan said the computers bad for sure but the wireing harnes maybe or may not be bad they just dint want to take the chance and hook up another working ecu to it and fry that one too. but i have a vq35 ready to drop and was thinking this is better anyway cause i can just get a 95-98 wiring harness and ecu and have plenty more ecu options. we just want to make sure its possible before i go buying parts
Old Dec 17, 2007 | 01:16 PM
Fr33way™'s Avatar
Wild for Width
Yes, 99 5spd ECU assuming you are using VQ30 timing case on the VQ35.
If you want to use the 5.5 ECU (which I don't think you are asking) you need to have a doner car to pull other various parts from the SAME car that the ECU comes from.
Old Dec 17, 2007 | 01:24 PM
rome06's Avatar
i know that ecu tuning and other options are limited on 99's , so lets say i got a 98' wiring harness, and then a 98' ecu, that would be alright correct? And as long as i use the timing components off of the 99' motor thats in my car right now, using a 98' harness and 98' ecu will work with the vq35 right?
Old Dec 17, 2007 | 01:34 PM
Fr33way™'s Avatar
Wild for Width
I see what you are saying. I would think that if you had a matching harness for the '98 ECU it would be fine from that point of view. You have to check into the aspects of the immobilizer and what other components are connected with that in the '99. I have a '98 and a '97 FSM so I can't say for sure.
Old Dec 17, 2007 | 01:44 PM
rome06's Avatar
yeah alright ill check it out, i just figured that all the aspects such as the immobilizer and some other components that have to do with a 99' were functioned by the 99' ecu which has to have the matchin harness, so i just figured if i switch out the harness with the matching ecu it would eliminate those components
Old Dec 17, 2007 | 01:46 PM
Fr33way™'s Avatar
Wild for Width
I tried to look it up but I recall the gauges and the ignition/fuel pump being related to the immobilizer system. Hopefully some '99/'00 guys can shed some light.
Old Dec 17, 2007 | 02:04 PM
adriena's Avatar
i was thining something like that also because right now the car isnt getting any fuel or spark. nissan told me that both the ecu and most likely the wiring hardness was bad because it may have melted some of the wires and now they are touching which fried the ecu. but if the ignition and fuel are related i guess i would have to find a way to handle all that i guess?
Old Dec 17, 2007 | 02:52 PM
adriena's Avatar
are the wiring harnesses from 99 to 01 all the same?
Old Dec 17, 2007 | 04:21 PM
JtzMax's Avatar
Whatchyou say?
^^^ don't think so mate! 99 is 3.0 ... 01 is 3.5 right?
someone correct me if i am wrong plz ...
Old Dec 17, 2007 | 04:31 PM
Fr33way™'s Avatar
Wild for Width
'01 is 3.0 but VQ30DE-K as opposed to 95-99 VQ30DE. The 3.5 became availible in 2002.
Old Dec 17, 2007 | 05:41 PM
rome06's Avatar
yeah nissan wants 1500 for the harness and 400 for the ecu hahaha we looked at them and just laughed to ourselves. but anyways i guese i will try to find a 99' 5spd ecu and harness and then get the vq35 , hopefully everything will be done in the next 2 weeks !
Old Dec 18, 2007 | 05:43 AM
JtzMax's Avatar
Whatchyou say?
Thanks! when did the 6spd come to life in the Maxima? I thought it was 01' but that wouldn't be the case with the 3.0 ... so I am guessing, 02'?
Mate ... check the scrap yards and see if you can find one used. If you're gonna buy new .... get a JWT ECU. (higher rev range)
Old Dec 18, 2007 | 06:19 AM
Kevlo911's Avatar
Kevlo for President
http://forums.maxima.org/showthread.php?t=547220
Next time do that or it will get locked.
And as for half your questions, how bout you search? Google will tell you what maxima years will have what...
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
Johnny9595
Sep 3, 2015 05:18 AM
