Individual throttle bodies
Old Dec 25, 2007 | 09:19 PM
Qbridg3's Avatar
Has anyone ever done that on a 4th gen? I have seen it done on some S2000s and some Lexus GSs.
Nobody? Nothing?
Old Dec 25, 2007 | 11:15 PM
darklegend06's Avatar
I have seen it on some Fairlady Z back in Japan.
It will be amazing if someone came up with ITB for our cars
Old Dec 25, 2007 | 11:43 PM
Qbridg3's Avatar
I found universal ITBs for a 6 cylinder on the bottom on this page. Quite pricey.
http://www.tweakit.net/shop/index.php?cPath=57_49_32
Looks really good.
Old Dec 25, 2007 | 11:54 PM
pmohr's Avatar
No more Maximas...
http://forums.maxima.org/showthread.php?t=318390
http://forums.maxima.org/showthread.php?t=352445
http://forums.maxima.org/showthread....&highlight=ITB
And of course: http://forums.maxima.org/search.php?searchid=86845
Old Dec 26, 2007 | 12:35 AM
m00njal's Avatar
Just to go off topic, a V8 ITB setup on a Detomaso Pantera, TEH SEXINESS
Old Dec 26, 2007 | 12:58 AM
20th maxstyle's Avatar
Looks really good.
In-line 6. When nissan's rocked all before the motors ended up french Peogeot in 02.
Old Dec 26, 2007 | 01:05 AM
pmohr's Avatar
No more Maximas...
The universal on that page isn't just for an I6.
Old Dec 26, 2007 | 01:31 AM
Can't imagine it being for a v6 or 8cyl. Other applications please.
Old Dec 26, 2007 | 01:40 AM
pmohr's Avatar
No more Maximas...
Did you actually look at the page? The photo provided above isn't representative of the kit.
Besides, a 6 port rail could easily be for a V12 as well.
Other applications being I4, V4, I6, V6, I8, V8, V10, V12, W16, etc etc.
Old Dec 26, 2007 | 08:20 AM
m00njal's Avatar
Haha,W16, that would be something to see =P
Old Dec 28, 2007 | 02:58 AM
throttlehappy46's Avatar
The tweak it website is actually based in Sydney, a few hours from where I live.
However, I found that you could use two SR20DE throttle bodies for a twin throttle body VQ with relatively big gains for minimal cost.
PS: My VQ35 is running the twin throttle body setup right now. The VQ intake ports are not really big enough to warrant fitting ITB's. Two SR20 65mm(2.5") throttle bodies from a B13 or B14 Sentra on a custom plenum inlet will make decent gains.
Old Dec 28, 2007 | 03:12 AM
AceofSpds's Avatar
wat
go outside and look at your LIM and edit your post
Old Dec 28, 2007 | 12:03 PM
sil80drifter's Avatar
too much work for the bang?
Old Dec 28, 2007 | 10:06 PM
lets see some pictures of your setup.
Old Dec 28, 2007 | 10:11 PM
NmexMAX's Avatar
dot dot dot ...
Not sure if this is what you posted, but I’ll shoot anyway.
http://forums.maxima.org/showthread.php?t=546676
http://forums.maxima.org/showthread.php?t=547787
And if it is what you posted, then on you post.
Old Dec 28, 2007 | 10:45 PM
Qbridg3's Avatar
I want to see that too.
Old Dec 28, 2007 | 11:12 PM
NmexMAX's Avatar
dot dot dot ...
What exactly do you want to see?
Old Dec 29, 2007 | 11:15 AM
the dual throttle body setup, is what he is mentioning.
WELL if you have ITB or something similar to that how does the MAF system wrk?
Old Jan 5, 2008 | 08:26 AM
ITB's can be enclosed in a plenum and suck through a MAF. The R32~R34 GTR's and the N14 GTiR used a similiar setup from the factory.
My setup has both throttle bodies joining to a Y pipe and then to the stock MAF. I will be upgrading to a Z32 80mm MAF shortly and since two SR20 throttlebodies have only a slightly larger cross-sectional area of a single 80mm MAF, it should pose no inlet restriction at all.
It all comes down to pulse tuning and air flow dynamics. ITB's are more suited to 12+:1 compression engines with 270+ degree cam grinds.
I may even end up fitting a Ford Lightning MAF or a Q45 MAF to allow my engine to breathe.
Old Jan 5, 2008 | 08:49 AM
Ultimate ITB setup on a VQ with the supporting mods would be a 6 cylinder version of the above
REDinLV
Aug 15, 2024 12:30 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
followthadollar
Sep 13, 2015 09:55 AM
