tranny rebuild - any good links?
Old Dec 31, 2007 | 07:55 AM
rouellette's Avatar
Ok, so is looks like my tranny is going. Loosing 2nd and OD in my auto. Slips through the 2nd and if I give it too much gas in OD it slips down.
So I figure I'll rebuild it.
Any good links for rebuilding?
Also, what do most kits contain? This seems to be just a seal problem and of course I'll need gaskets and such but I certainly don't need to be replacing any gears, etc.
-Thanks
Old Dec 31, 2007 | 08:05 AM
f550maranello2's Avatar
get another one.. rebuilding is a waste of money.. i have one with 9k miles on it if u want..
Old Dec 31, 2007 | 09:21 AM
dgeesaman's Avatar
Maintenance Monster
car-part.com
Seriously, rebuilding an auto is not worth it. Used are plentiful and overall these are pretty durable trannys. So if you get one with low mileage you'll get the best bang/$
Old Dec 31, 2007 | 01:30 PM
nissana32's Avatar
i will say you should at least try to fix it yourself, i wanna do it myself even if i buy a used/rebuilt one still i will keep old and fix it for future becoz i am going to keep it for at least ten more years
just give me your email address and i will send you complete service manual (as i am unable to attach due to space limit) if you want.
Old Jan 9, 2008 | 09:58 AM
rouellette's Avatar
why is rebuild a waste of money? Seems like I'm losing 2 and 4. That's just valve seals, right?
Old Jan 9, 2008 | 10:29 AM
pmohr's Avatar
No more Maximas...
-Thanks
If you get a full rebuild kit, you'll get o-rings, seals, gaskets, clutches, probably steel plates, and bands. There are no 'gears' in an automatic in the traditional sense, only the planetaries and on the input/output shafts.
It could be a large number of things; passages plugged up, failed seal(s), failed gasket(s), failing pump, sticking check ball, bad solenoid - who knows until you take it apart.
Basically, unless you just want to do it for the experience and you're sure that you can do it correctly, don't bother. Get another for $300 and be done. A lot of times you can get them cheaper than that - I got one for free from Dixit and one for $250 at a junkyard. Local pick and pull sells transaxles for $80 a piece.
Automatics are pretty easy to rebuild, but it helps vastly if you have a good amount of experience in doing them. Not something I'd recommend for a beginner if it's your only vehicle and you need it back on the road quickly.
Matt93SE
May 24, 2019 02:58 PM
Matt93SE
Apr 8, 2018 09:23 AM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
CreativeSkillz
Aug 26, 2015 04:23 PM
seesole
Aug 26, 2015 11:22 AM
