installing DRL (daytime running lights)
Old Jan 3, 2008 | 01:21 AM
9maximuz8's Avatar
hey guys
does anyone know how to install DRL on a 98 maxima. I think there used to be one somewhere on these forums under the how to's but i dont see it anymore.
anyway im importing the car to canada and i have to have DRL to pass inspection, any help would be great.
thanks
Old Jan 3, 2008 | 06:22 AM
Kevlo911's Avatar
Kevlo for President
I don't know how to add the factory one on, but you can add a relay so the headlights only come on if the car is on thus when you turn off the car the headlights will come off. Just download the FSM and look thru some wiring diagrams and you should be able to figure it out
Old Jan 3, 2008 | 10:53 AM
kzoosho's Avatar
Just what kevlo said. If you can find the circuit that the headlights are on yu can tap that with a relay that is wired to the ignition wire of the car. That way once on the lights turn on and once off they turn off.
Old Jan 3, 2008 | 11:28 AM
Husker Z's Avatar
Out of curiosity, why do you want to have DRL's? Every vehcile I've had, I disable them, all it does is run a low current to the bulbs and the blow out prematurely. I suppose if you rig it so the headlights just come on each time you start it up, it will run a normal current, but you'll still blow through bulbs quite a bit faster. Just curious.
Old Jan 3, 2008 | 11:31 AM
kzoosho's Avatar
Hes in canada. Kinda required.
Old Jan 3, 2008 | 11:41 AM
MaximaSpd85's Avatar
dumb question: how do the maximas in canada have it done? meaning 4th gens. do they come like that brand new?
Husker Z's Avatar
Canada requires DRL's huh? There, I learned something new today, thanks.
Old Jan 3, 2008 | 11:43 AM
99BlackMaxMS's Avatar
I know they come from the factory with it...but I don't know how they wire them up.
Old Jan 3, 2008 | 11:51 AM
kzoosho's Avatar
Thats what the forum is all about man. Learning when you can.
Old Jan 3, 2008 | 12:00 PM
Husker Z's Avatar
Super, I just bought a 97 SE today, so I'm trying to learn a bit as I read and also chime in where I can so I can get 15 posts and formally introduce myself. Looks like a pretty cool place so far, very well organized and laid out.
Old Jan 4, 2008 | 12:41 AM
9maximuz8's Avatar
thanks guys ill try what Kevlo911 said and after i pass the inspection ill just disable it
Old Jan 4, 2008 | 02:16 AM
atticusj's Avatar
The way DRL's work in OEM applications, is that they switch the ground side on the high beam to power, that way the bulbs are run in series with each other, so each will only be seeing 6.5-7 V, instead of full battery voltage. I've actually hooked these up on my car, with 2 relays. One that switches the ground side of the headlight to run to the other, and then one to switch that back when the headlights are normally on. There's plenty of ways to do it; you could even just run relays to each individual headlight, and put a decent sized resistor on there to dim them.
MaximaDrvr
Aug 19, 2015 08:20 PM
spidgeon
Aug 18, 2015 05:46 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
