Installed CAI, now I can't keep her running!
Old Jan 3, 2008 | 08:07 AM
ZachsMax's Avatar
Ridin' Spinnaz
A friend and I installed the Place Racing-style CAI that runs through into my wheel well.
Since doing so, I've been having some problems... when I start the car with the MAF connected, it stalls out right after I start it. If I unplug the MAF, I can get it going (but it stalls randomly) and the car starts "shuddering" every time I hit 2250 RPM.
I already tried swapping out the MAF sensor, checked all the hoses for leaks (or so I think), and now I'm stumped. Anybody have a problem like this before? Any info is much appreciated!
Old Jan 3, 2008 | 08:15 AM
Mxrider52's Avatar
I support for what?
Sounds like an air intake leak. Has to be somewhere on the intake. Getting to much air. Can you keep it running if you hold the gas down some?
Old Jan 3, 2008 | 08:24 AM
ZachsMax's Avatar
Ridin' Spinnaz
Yeah, I can. I had it running at about 40mph on cruise control and it didn't stall until I stopped. It seems to run fine if you keep it at about 2000 RPM. Every time I put it into reverse it would stall as well, unless I gave it some gas right away.
Old Jan 3, 2008 | 08:34 AM
Qbridg3's Avatar
Maybe you have the MAF installed the other way around?
Old Jan 3, 2008 | 08:38 AM
96blkonblkse's Avatar
Sure sounds like a MAF problem. As someone said are you sure you put it the right way? The arrow should be pointing towards the engine. Other then that did you happen to drop your MAF at all? They are pretty sensitive. Did you hook up the IACV and valve cover breather line?
Old Jan 3, 2008 | 09:14 AM
91parkave's Avatar
x2 the part where the MAF adaptor is installed is the same side the air filter section should be.....otherwise maybe you should re-gorund your MAf and see what happens
Old Jan 3, 2008 | 09:51 AM
ZachsMax's Avatar
Ridin' Spinnaz
There's a flange on the CAI that can only connect to the MAF in 1 way.. so it's installed correctly. I'm going to try checking for leaks and swapping out the MAF wiring harness with another.. any other suggestions while I'm in there?
Thanks for all the replies BTW
Old Jan 3, 2008 | 10:36 AM
91parkave's Avatar
or just for laughs restet your ECU and maybe.......
Old Jan 3, 2008 | 10:45 AM
kzoosho's Avatar
Please make sure your iacv tube is hooked up.
Old Jan 3, 2008 | 12:37 PM
SmileyFace's Avatar
+1 i had the same prob but mines kept falling of and my car would just stall.
Old Jan 3, 2008 | 12:49 PM
ZachsMax's Avatar
Ridin' Spinnaz
All 3 tubes and the temp. sensor are hooked up.. I'll check the connectors this afternoon and make sure they're all snug.
Old Jan 3, 2008 | 12:54 PM
kzoosho's Avatar
Have you ran codes?
Old Jan 3, 2008 | 02:17 PM
ZachsMax's Avatar
Ridin' Spinnaz
Yeah, the only code I got was the MAF code when the MAF was unplugged. Other than that, no CEL and no codes.
Old Jan 3, 2008 | 03:36 PM
mevjen's Avatar
The self-oil changing max
I had the same thing when I jerry-rigged a short ram on my car. Make sure that there is nothing blocking the airflow, and that there is no leaks after the MAF.
Old Jan 3, 2008 | 04:21 PM
NmexMAX's Avatar
dot dot dot ...
That/s actually not entirely true, it’s more a matter of unmetered air (blind air) getting into the engine, and the MAF doesn’t see it so it does not get compensated for.
Also, for us to really help, we need a picture of the engine bay, most namely in the TB/MAF/PCV breather area.
Old Jan 4, 2008 | 08:22 AM
ZachsMax's Avatar
Ridin' Spinnaz
I'll take a pic as soon as I can and post it. I checked last night, and the MAF isn't backwards and all hoses appear to be connected properly.. the only thing in line between the MAF and the TB is the stock flexible boot, which I reused from my old intake setup (so I doubt that's leaking). It could very well be the MAF wiring harness.. I'll try swapping it out.
Old Jan 4, 2008 | 09:04 AM
aventerav's Avatar
Really sounds like MAF.
Old Jan 4, 2008 | 11:29 AM
[s3]'s Avatar
Vacuum leak somewhere and OHM test the MAF
Old Jan 4, 2008 | 11:54 AM
NmexMAX's Avatar
dot dot dot ...
How about a voltage test instead?
Old Jan 5, 2008 | 08:21 AM
jEsuSmAx's Avatar
Maxima fanatic!!!
just check the maf and that the tubes are pluged correctly, we dont want vacuumm leaks
JRod28
Feb 4, 2016 11:07 AM
Maxima_Joe
Nov 25, 2015 08:19 AM
Finkle
Sep 27, 2015 09:53 PM
lowpost99
22
Sep 2, 2015 04:38 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
