motor mounts
Old Jan 7, 2008 | 02:39 PM
goldtooth's Avatar
motor mounts
I have a 98 SE Manual. It doesnt have the electronic front mount. Which year maximas and trims and whatnot can I pull out motor mounts from to put in my car?
Old Jan 7, 2008 | 02:50 PM
JonBlz's Avatar
a.k.a. STuNtMAN
das great u dont have the front electronic motor mount y dont u just get the ES inserts they are great bro i have them on my maxim along wit me left & right mounts poly filled
Old Jan 7, 2008 | 02:59 PM
goldtooth's Avatar
I just want OEM to be as smooth as possible.
Old Jan 7, 2008 | 03:04 PM
JonBlz's Avatar
a.k.a. STuNtMAN
i believe maximas from 95-96 dont have the sensor on it
Old Jan 7, 2008 | 03:16 PM
CRiME's Avatar
oem ftw!
The GXE maximas don't have the electronically controlled front mount. so if you can find a manual GXE, you can get them from that. FWIW, i got all 4 on ebay for $99 shipped brand new, oem. seller I got them from was "abcmarts". my car is a GLE and does have the electronic front mount, but to save some $$$, i chose to replace all 4 with standard mounts. first impression was that there was more vibration mainly at idle. it seems to be getting better over time though, I guess the mounts are softening up.
Old Jan 7, 2008 | 03:37 PM
goldtooth's Avatar
ok, thanks guys for your inputs, but I dont need any info on where to get the mounts or why Im not getting the ES inserts..... only which year maximas I can use the mounts from
95-99 only? or can I go up to 03+?
as I see it, pretty much any maxima?
except for the tranny side mount, which has to be from a manual maxima
Old Jan 27, 2008 | 03:18 PM
t6378tp's Avatar
Turbo 3.5
I know 95-97 for sure, cause I have a 97 auto and used the front, rear and passanger mounts from a 95 5-speed. I do not see why 98 and 99 would be any different
Old Jan 27, 2008 | 03:29 PM
njmaxseltd's Avatar
A new mount from NAPPA is about 25 bucks, why would you even consider putting a used one in?
Old Jan 27, 2008 | 04:18 PM
goldtooth's Avatar
D'oh! I dunno why I forgot to check with them....
Old Jan 27, 2008 | 04:38 PM
JSMax's Avatar
Sold
My 97 SE is not electrical.
I just did the ES mounts and they rattle the whole car.
Old Jan 27, 2008 | 08:54 PM
t6378tp's Avatar
Turbo 3.5
cause I poly filled them
and what napa are you going to the cheapest they have are 83.00 not 25.00
http://www.napaonline.com/MasterPage...=8&SubCatId=10
http://www.napaonline.com/MasterPage...10&SubCatId=14
Old Jan 27, 2008 | 09:19 PM
TunerMaxima3000's Avatar
learn something new every day, I had no idea the max had an electric mount in it, I'm curious how this works?......anyone?
Old Jan 27, 2008 | 09:27 PM
f550maranello2's Avatar
yea it does.. and they dont do ****..
Old Jan 27, 2008 | 10:11 PM
t6378tp's Avatar
Turbo 3.5
here is a pic of one on this thread, it's just alittle bigger than the
non-electric
http://forums.maxima.org/showthread.php?t=551718
Old Jan 28, 2008 | 12:35 AM
vqmaxman's Avatar
I am assuming Nissan had It this way Is,becsue If It goes bad the SES light will come on I and I am sure they just said forget It and left this way.
Old Jan 28, 2008 | 12:53 PM
humaras's Avatar
guys, while we are on the topic of motor mounts, I took my car in for a transmission refill and also a check and my mechanic told me that the "rear" motor mount is bad...seems like when he shifts the car through the gears the engine moves.
So my question to you folks who have had your motor mounts replaced...was it because of wear and tear, and are there any differences to the different mounts between the different editions -GXE, SE and GLE. I have a GLE and recall that these are "liquid" filled mounts... but I am also curious as to how much it would cost (labor) to have these changed?
Old Jan 28, 2008 | 01:14 PM
m00njal's Avatar
uh......my car's engine has ALWAYS moved when you put it into gear, isn't this part of the role of motor mounts? Let alone my car, every car.....I've seen does this. Check again with the reasoning of your mechanic I guess? Either that or I'm in need of motor mounts myself =P
172k FTW!
Old Jan 28, 2008 | 02:18 PM
t6378tp's Avatar
Turbo 3.5
even with new mounts the engine will move alittle, they are made to have alittle give. how much was the engine moving around that is a better way to judge
Old Jan 28, 2008 | 05:41 PM
humaras's Avatar
it was a good amount, but he is a good guy that i have gone to for many years for the maxima...and he told me it was not in a particular hurry...
so im wondering-- did the rubber tear?
when he shifted the gears, the engine moved some--can't judge how much...but it popped up a bit and came down. hope that helps. but so far...when my car idles (normally-- occasionaly i have the high idle issue)-- it is very quiet and normal.
Old Jan 28, 2008 | 05:58 PM
mounts usually just get tired, they dont really rip. the inner bushing can separate from the rubber / seize to the through bolt, but not on 1 piece mount.
Is that all the ele. is for, to tell when the mount has gone 'bad', I have not heared of this before.
Old Jan 28, 2008 | 07:19 PM
CRiME's Avatar
oem ftw!
The electronic mount is made up of liquid chambers. the goal of it is to dampen vibration at idle. when the engine is idling, the mount receives a signal from the ecu (i guess it depends on your RPM) to relax or soften up. Once the RPM's climb, the mount is energized and stiffens up to better deal with the load of the engine. General consensus is that it doesn't do anything but, on my car at least, i did notice a difference on the first startup with my new mounts. there was more vibration being transferred to the cabin than there was with my 4 old mounts. i was pissed but it seems to be getting better over time.
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
