Idea for 95-96 Taillights
Hi guys,
Seeing that other thread about ebay red clears gave me an idea.
Currently, there are those "diamond cut" red clears for the 95-96 maximas, but I personally think they look too modern for our cars.
My idea is to take apart the tail light and put something on the inside of the red and clear pieces so that you can't see directly through to the ugly rectangle shapes.
Some questions though:
1. Does the red clear plastic have the rectangles? or is it inside?
2. What should I use to go over the red/clear piece? I was thinking some of the same stuff that the vq power tutorial said to. that or the tint-like stuff
What do you guys think?
I don't have the lights, these are just my thoughts:
1. The rectangles are built into the housings, meaning the lenses are clear and the rectangles are on the inside.
2. From the looks, there may not be enough room to put something in there.
And another thing to think about, you will be taking apart a new $130ish set of lights, be careful.
These lights are actually growing on me. I sort of like them.
David
David
Hmm...this brings up another question.
Could I take the lenses off the diamond cut lights and switch them with the OEM amber ones? I'm sure that this is a longshot and the shapes probably aren't the same, but is it possible?
Also, has anyone been able to take apart the ebay tails? Do you guys think it'd be the same process?
Also, $130 + a few dollars for supplies is much better than $225ish for DavidLs, so I think this is worth some time to think about. Perhaps next paycheck I will buy a set to see if I can do anything with them.
ebay tails to take apart: most surely, yes, since most tails are manufactuered the same way ( 2 pieces stuck together)
as for the David L's.. I'd take those first.. then I'd take the ebay ones
Why? To get rid of the amber lense on the OEM tails and replace them with white/clear.
Also...I haven't seen a set of DavidLs for a while, plus I could save $100...
I can buy a lot of Taco Bell for $100.
i was thinking about taking those eBay lights and just tinting them pretty dark, you wouldn't be able to see directly into the light and see the rectangles and i think it would look good on black paint.
What about these??
http://cgi.ebay.com/ebaymotors/97-98...spagenameZWDVW
I'm itching to get that amber out of there, I just installed clear corners and they look GREAT on my boy blue, so the only amber left is the tails!
but what does the housing ( reflective bowl) of the OEM tail look like then?
it may even look worse then the ebay ones...
Negative, if I can get them to look better than the ebay ones (which I kinda find tacky), then I'd rather do that.
Digitized, you have a good point, I'm not sure what it looks like, I have never seen the inside.
Ok, supposing the inside of the OEM housing is ugly, what could I put under the clear housing to make it look more like an OEM red clear? What about that material from the VQ power tut (Acrylic flourescent light cover sheet)? Is it flexible enough (supposing I cut it to the correct size) to put it in behind the clear plastic (on the inside)? If so, how could I affix it there without seeing glue/residue/tape?
Boy, don't you love questions?
yeah bro, we kind of went off topic on 97-99. my bad.
i dont think what you are talking about will work because, from what i can tell, there is no reflector in the ebay 95-96. i would think your best bet would be the flourscent light stuff, but do the inners and outers so they match. but i don't have/never opened 95-96 so i'm just guessing.
Here is a FS thread that has pics of the insides:
http://forums.maxima.org/showthread.php?t=548259
Look about 2/3 the way down the page.
i may be completely off, but has anybody ever tried to fit the clear outer upper reflector piece from a 97-99 into the 95-96? looks awefully similar to me...
*edit* or is it the actual lense on the 95-96 that is orange? if thats the case (which i'm assuming it is) then taking the lens off the ebay tails and putting it on the oem housing should work.
I think the best option here (other than DavidLs obviously) would be to get the ebay ones, and take them apart.
Then:
1) see if the ebay plastic would fit on the OEM housing
2) If it can, check out how it looks
3) if it looks crappy, add the flourescent light plastic stuff to the inside of the plastic.
I suppose my first question is: if I were to do this, what would I use to 1) hold the housing and lense together and 2) hold the flourescent light stuff to the inside of the lense without it looking like I glued it in there?
Then:
i don't think you'll need the fluorescent light stuff because the oem lights have a reflector piece in them to calm down the super-clear ebay lens. i think it should be a nice looking light.
to hold the housing and lens together just reheat the sealant and screw them back togther.
tarun900
19
Dec 20, 2021 06:57 PM
maxima297
Sep 30, 2015 03:32 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
