Passenger Motor Mount
Old Jan 13, 2008 | 04:10 PM
speed racer's Avatar
I'm trying to replace my side motor mount with a polyurethane one I made. It seems impossible to change it with the motor in. Does anyone have any tips to get it out? I'm particularly concerned about the bolt from underneath.
Old Jan 13, 2008 | 05:19 PM
max ride 41's Avatar
i believe you have to jack it up to take the weight off of the mount. check the stickies, there should be a write-up.
pmohr's Avatar
No more Maximas...
http://forums.maxima.org/search.php -> http://forums.maxima.org/search.php?searchid=103029 -> http://forums.maxima.org/showthread....er+motor+mount
Old Jan 13, 2008 | 05:21 PM
pmohr's Avatar
No more Maximas...
Don't need a jack for the passenger side. Actually, as far as I've ever done on Maximas (A32, A33, A33B) you don't need a jack for any of them as long as all of the others are installed (obviously for the crossmember, you need the two side mounts in place).
Old Jan 13, 2008 | 07:29 PM
I saw the third link after a search. The vertical bolt on the bottom is a tight fit to get off. It seems like you need a deep wrench to get it off. That in itself will cause something to obstruct you from turning it. Than trying to go from underneath you have the drive belt in the way. I guess I'm looking more for a technic for getting that bolt off.
Old Jan 13, 2008 | 07:30 PM
I jacked the car up. It didn't do anything. I replaced the auto tranny mount. Simple but you have to remove alot of stuff to get it off.
Old Jan 13, 2008 | 11:52 PM
i meant jack up the motor on the passenger side, not jack the whole car. doh, and i was wrong anyway. live and learn.
Old Jan 14, 2008 | 02:36 AM
JonBlz's Avatar
a.k.a. STuNtMAN
thats great ploy filled mounts i have the left & right poly filled nd the ES inserts in my front & rear they r great
Old Jan 14, 2008 | 10:51 AM
Yea, I have all four. I did them myself. I'm doing the center one when it gets a little warmer.
RWCreative
Sep 21, 2015 11:01 AM
QueensMAX
Sep 15, 2015 04:14 AM
Bonka
Sep 14, 2015 11:18 PM
spidgeon
Sep 9, 2015 03:36 PM
Colossus
Sep 9, 2015 05:46 AM
