Battery and E-brake indicator lights
Old Jan 14, 2008 | 04:51 PM
DJMaxGLE's Avatar
My battery and e-brake indicator lights will come on at random times and stay on for a few seconds. They turn on simultaneously and then turn off again. Do I have a bad battery, brake fluid leak, what? Any guesses?
Old Jan 14, 2008 | 04:58 PM
99BlackMaxMS's Avatar
Your alternator is crapping out. Get one asap before you get stranded somewhere.
Old Jan 14, 2008 | 05:11 PM
Nopike's Avatar
^^^ may be right, but make sure the posts of your battery are clean and you have a good connection to the battery.
Old Jan 14, 2008 | 05:20 PM
DJMaxGLE's Avatar
Yeah I was thinking I should check the battery terminals. Now, the lights aren't always on, just periodically. So would the alternator be working fine while the lights are off?
Old Jan 14, 2008 | 06:00 PM
xkazik's Avatar
Thats the alternator. had the same problem , some time soon the lights will stay on and u your car will shut off.
Old Jan 14, 2008 | 06:59 PM
hermtm2's Avatar
It will be alternator's problem. I ignored the signs and drove onto downtown. Like 15 min. later, the engine was stopped on the traffic. The car was towed.
Old Jan 14, 2008 | 08:03 PM
maxima92se's Avatar
Alternator. Well the charging system.
Old Jan 14, 2008 | 08:10 PM
heynow's Avatar
Alternator. Lights go on when the alty can't output the needed juice.
Old Jan 14, 2008 | 08:21 PM
andrei3333's Avatar
I will say this: Alternator related, unless the ligthts are always on no matter what you do!
read between the lines if you like...
Old Jan 14, 2008 | 09:01 PM
Delvin's Avatar
Get your charging system (alternator) checked before you go out there and start replacing things. Most of the time the lights on the dash start to come on like that when the voltage starts to get below a certain point which is an indicator that the alternator is starting to go bad. But to be sure go somewhere that will check the system out for you at no charge (Autozone is one place) so you can know for sure that the alternator is the problem.
Old Jan 16, 2008 | 01:48 PM
DJMaxGLE's Avatar
I took the car into a mechanic today and they said the alternator works just fine. The temperatures have been in the single digits and teens lately. Could that have an effect on any electrical parts?
Old Jan 16, 2008 | 02:18 PM
97_Roadrunner's Avatar
Your belt or the tentionner might be your cause....
Old Jan 16, 2008 | 03:28 PM
andrei3333's Avatar
Im tellin you man, check the sub harness, when this exact thing was happening to me the alty tested fine as well, i still replaced it and it was not the case
CHECK the subharness that connects to the alty...trust me, save your self the agony
Count down to your car dying has begun . t - 3 months or so !!!
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
JoshG
Sep 5, 2015 10:10 PM
