for those who have LED clearance corners
Old Jan 17, 2008 | 03:26 PM
Max Noob's Avatar
I jsut looked at super bright led web sight. my amber clearance corners are going out. the amber film is peeling. i want to replace them with amber LED's so that i wont have that problem again. the sites has a 1157 LED...
here is the link. http://www.superbrightleds.com/tail-brake-turn.html
do they work at both brightness lvls. ie..low ON and then bright ON when turning.
do they fit well?, are they bright enough to be used as a turn signal for others to see.
do i need any additional hardware to use them correctly?
thanks..
let me know whatu gusy think of them.
Old Jan 17, 2008 | 03:29 PM
kzoosho's Avatar
I did a complete led retro but i would stay away from led pnp bulbs. They are dangerously dim in the day time.
Old Jan 17, 2008 | 03:38 PM
Max Noob's Avatar
so the daytime flash for a turn signal isnt bright enough to see even if its amber? i plan of keeping the regular halogen brake lights. its only for the clearance corners.
other than that, do they blink at the correct speed without any other stuff connected to it?
Old Jan 17, 2008 | 03:43 PM
kzoosho's Avatar
No you will get hyperflash and they will not be seen. jtsmith or something like that has the switchbacks that are a ton brighter . *EDIT* heres mine.
Old Jan 17, 2008 | 03:47 PM
Max Noob's Avatar
thanks alot man. no more plug n play bulbs for me. how much would it costs me to get a set a functional retro amber clearance corners from you?
Old Jan 17, 2008 | 03:49 PM
kzoosho's Avatar
It all depends on what you want to do. Also if you want pm me and i can show you links to purchase everything and go from there.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
