How to get rid of check engine light after intake install. Reset codes/ecu
Old Jan 18, 2008 | 10:54 PM
maximaserg's Avatar
I installed Injen intake. Got cel.
How can I get rid of it.
What will happen if I just leave it on? Anything bad?
Old Jan 18, 2008 | 10:56 PM
chazmcgee's Avatar
hey man go to radio shack and spend 99 cents for a 4.7k resistor. take the plug that isnt plugged in (IAT Sensor) make a U out of the resistor slide it in electric tape zip tie and its gone. thats my run down but im pretty sure its in the stickies.
Old Jan 18, 2008 | 11:05 PM
JSMax's Avatar
Sold
reset the ecu. Pull the code. Fix the problem Could be a loose connection on the MAF or something simple that you overlooked.
Old Jan 18, 2008 | 11:54 PM
maximaserg's Avatar
the thing is, is that the intake that i got was for the 95-98 maxima, which has a different sensor connector than a 99. So we covered up the holes where the old one goes, and drilled a hole for the new one. We just used the rubber piece from the stock intake and plugged it right in. It works fine. Just the CEL is on.
Old Jan 19, 2008 | 12:18 AM
pmohr's Avatar
No more Maximas...
Then how about you pull the codes?
That's like asking a doctor 'I hurt, what's wrong with me?' with absolutely no further explanation.
Pull the codes, then come back.
Old Jan 19, 2008 | 12:31 AM
maximaserg's Avatar
lol.
Well the CEL went on right after the intake was installed.
So its prob the intake.
Old Jan 19, 2008 | 12:42 AM
pmohr's Avatar
No more Maximas...
lol.
Okay...
Did you check your codes?
No.
Old Jan 19, 2008 | 01:09 AM
ptatohed's Avatar
Licensed to Spell
Check the codes. And don't ask us how because it's in the Haynes / Chiltons which, for only $15 ea, you should already own. It's cool that we can read the codes on our car for free / without a reader.
Old Jan 19, 2008 | 01:43 AM
maximaserg's Avatar
k thnx. ill pull this back up when i get the codes.
Old Jan 19, 2008 | 03:35 AM
wirelessdude04's Avatar
pull the codes buddy... Notice any gains
Old Jan 19, 2008 | 07:02 AM
KRRZ350's Avatar
lol.
Code P0wnd = means your intake isn't operating properly.
Probably a maf or iat code from at one point having them disconnected with key on, read. clear, and...oh yeah-
I know that you know that I know that you know.... and thats why I know that you know.... and why no-one else, at least in this thread, will know.
Old Jan 19, 2008 | 09:57 AM
maximabebe's Avatar
...or yank a sensor from a 95-95 and splice it into ur 97-99 harness, worked for me.
Old Jan 19, 2008 | 10:45 AM
ptatohed's Avatar
Licensed to Spell
Are you asking him if he noticed any gains? Or are you telling him to notice gains.
maximaserg's Avatar
yea?? Sounds like a plan.lol
I actally have a buddy with that year max, but he doesnt give a damn about it. lol
Old Jan 19, 2008 | 10:46 AM
maximaserg's Avatar
after 40 mph i feel more power, other than that it looks cool and make a hissing noise. lol
Old Jan 19, 2008 | 10:49 AM
MDeezy's Avatar
Old Jan 19, 2008 | 09:12 PM
asking lol well thats answered
Old Jan 19, 2008 | 09:39 PM
JonBlz's Avatar
a.k.a. STuNtMAN
i installed my fathers intake wit no problems nd he neva had a CEL nd he has a 99
Old Jan 21, 2008 | 09:42 PM
maximaserg's Avatar
transmission seems to sometimes take too long to up shift into the next gear, and the engine rpm's at highway speed (65mph) are around 3500rpms when they should be between 2500 and 3000rpms,like it can't go into a higher gear, and my CEL is on.
Can any of the following codes be a reason for the noted above??
I connected the ecu to the code reader
popped up
P035 knock sensor
Bank 1 i think.(have no idea what it means)
P1130 Manufacturer control air( probbaly my intake that was installed the other day)
P1605 I think it said sup input, output auxilary ports?? IDEAs??
Thanks a lot guys.
Going to mechanics tomorrow.
Old Jan 21, 2008 | 09:54 PM
pmohr's Avatar
No more Maximas...
popped up
P035 knock sensor
Thanks a lot guys.
http://forums.maxima.org/showpost.ph...26&postcount=1
Old Jan 21, 2008 | 10:19 PM
maximaserg's Avatar
so my tranny might not be going bad, and its just the sensors making it that way?>?
Old Jan 22, 2008 | 07:01 AM
hectorc's Avatar
Upper Midwest Wheel Whore
It's cold outside. I say your tranny is shifting a lil harder because the fluids are not warm enough.
scutmud
Aug 16, 2018 10:56 AM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
