Ace Intake Adapters Are The Best :)
Old Dec 9, 2001 | 04:32 PM
  #41
conig's Avatar
got this peice from homedepot so I could build my brother one for christmas but theres not enough of a lip to secure a filter to.
should it be glued on? will it fall off ? any ideas?
Old Dec 9, 2001 | 10:05 PM
  #42
party_boy's Avatar
If the lip is not long enough
just get a pipe to fit over it and superglue it together. That way you have a nice long lip to attach the filter to.
Old Dec 11, 2001 | 04:49 AM
  #43
KWheelzSB's Avatar
Clear Silicone
I like the pipe idea to extend the mounting surface for the filter, but personally, I'd go with clear silicone adhesive instead of superglue, for two reasons:
1) It's easier to work with b/c it doesn't dry as quickly
2) It's more likely to seal the bonded surfaces airtight, which will prevent unfiltered air leaks into the engine.
Old Dec 11, 2001 | 12:25 PM
  #44
conig's Avatar
but is it that heat resistant? can I just glue the filter to the braket at $15.99 for the filter and $0.87 for the bracket you could just buy a newone instead of cleaning it. although its just as easy to clean with the filter attacked.
matt
Old Dec 13, 2001 | 04:17 AM
  #45
KWheelzSB's Avatar
matt
Clear silicone is plenty heat-resistent for that application. No prob. whatsoever.
I guess if you wanted, you could buy a new filter every time instead of cleaning it, although I don't know why you'd do that if you could just clean it. Btw, what kind of cone filter are you getting for $15? That's pretty cheap.
Btw, I wouldn't try to clean the filter with it still attached to the car - you risk getting contaminants in the MAF or intake manifold.
Old Aug 19, 2002 | 09:45 PM
  #46
Nismo3112's Avatar
Custom User Title
The Genaric ones at Autozone, that come in grey, red, blue...
It's $19 down here...
Are ALL filters reusable?!??
Whats the best way to clean one? I'm seriously considering supergluing one of those adapters to my filter..and i want to be able to reuse my filter..if possible. thanx
Old Aug 19, 2002 | 11:51 PM
  #47
eibachmax's Avatar
thats the exact setup i am running, the homedepot adapter, and autozone filter, total cost 21 bucks, i didnt glue the adatper to the filter though, just made the clamp tight, its been 2 months and it sounds good,
Old Aug 20, 2002 | 12:54 AM
  #48
Quack 2x's Avatar
Don't know about *all* filters, but the K&N, HKS, and other foam-type filters are reusable. The methods for cleaning and pre-oiling if called for may differ. Other paper filters may have their own oils or filtration enhancers.
Don't know about the superglue thing. If you have enough of a pipe from your adapter, you could just hose clamp the thing on. Makes it really easy to take the filter out to clean, especially for the K&N filters where you either soak them or flush them out from the inside. Hard to do with the filter still on the motor...
Hope this helps,
Quack2x
Old Aug 20, 2002 | 11:23 AM
  #49
Nismo3112's Avatar
Custom User Title
Hey everyone..I just went to menards and bought the piece he described from ACE's..the flange circle is about 3 1/8 in. and the inner diamiter of my filter is 3"..and BELIEVE me, once u squeeze the filter on there, add a little superglue, the jaws of life couldnt pry that thing off..IT's the perfect adapter!!
Old Aug 20, 2002 | 01:14 PM
  #50
BluFlame's Avatar
I'm still looking for this adapter, home depot around me doesnt have it.
Old Aug 20, 2002 | 04:27 PM
  #51
Nismo3112's Avatar
Custom User Title
Try Menards or Lowes in the electrical department
Just finished the $15 upper intake and the ACE adapter!!
SOUNDS AWESOME!!!!!!!!!!!
Old Aug 20, 2002 | 04:58 PM
  #52
mzmtg's Avatar
Minister of Silly Walks
FYI, HKS isnt quite reusable. You have to replace the green foam part when it gets dirty...
Old Aug 21, 2002 | 02:00 AM
  #53
Quack 2x's Avatar
Yep, you're right. Forgot about that. I thought the original ones were washable, and the newer ones were disposable for some reason.
Been awhile since I've seen those in a store.
Aloha,
Quack2x
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
MichMaxFan
Sep 30, 2015 09:18 AM
