One Piece Headlight Sets... worth it?
Old Jan 25, 2008 | 10:25 PM
S Cranaw's Avatar
Hey all. I got in an accident the other day and cracked one of my headlights. I currently have the black housing headlights paired with the separate black housing clearance lights.
Since I have to get new headlights regardless, I saw the infamous one piece black headlights with the bulb conversion on ebay. I really like the look of these lights, but I seem to remember when they first came out from CE that people were complaining of a bad beam pattern. Just wondering how bad/dangerous the pattern is from the one piece headlights. Pics are appreciated.
Thanks.
-Steve
Old Jan 25, 2008 | 10:30 PM
mastere954's Avatar
the pattern is in a W shape,worth it for looks, ut if you are picky about the beam pattern being even then i would not spend the $200
Old Jan 25, 2008 | 10:52 PM
S Cranaw's Avatar
Thanks for the info bro. Now, do the actual lighting abilities deteriorate (meaning less aimable/noticeable/amount of light) when compared to a more stock set up?
-Steve
Old Jan 25, 2008 | 11:10 PM
97maximaman's Avatar
If you get them you would need a projector retro to make it worth it. For the short time i had these they sucked. Luckily i was able to return them under a 30 day money back no hassle policy. If you like the one piece look then go for the 1 piece cefiro lights. The r34's suck for the money there asking.
Old Jan 25, 2008 | 11:17 PM
2themax99's Avatar
i had the r34's for a while and they looked fine. the factory lighting isnt very good to begin with, so the r34 IMO werent that bad. i ended up doing a dual bixenon retro in them however. i thought they were worth it tho for looks and decent output. the main thing is u can see at night. maybe not the best, but u can at least see.
Old Jan 26, 2008 | 02:12 AM
wiggafly808's Avatar
They look nicer, but mine needed small kine custom modification..
The lights are fine.
Old Jan 26, 2008 | 07:56 AM
bigpulve+'s Avatar
Umm are we talking about R34s or Cefiros?
Old Jan 26, 2008 | 09:38 AM
S Cranaw's Avatar
Yeah i'm talking about the R34's. I don't feel like spending the extra on the body work if I were to do the cefiros. I guess I have my answer. I'm just going to throw the old stock ones back on that i have sitting on a shelf. (keep it cheap)
Thanks a lot for the input guys.
-Steve
Old Jan 26, 2008 | 11:33 AM
wirelessdude04's Avatar
for the crfiros you can install them yourself took me about 4 hours to do it but they fittted perfect
Old Jan 26, 2008 | 12:39 PM
icedout's Avatar
r34s and some hids will do the trick...
Old Jan 26, 2008 | 12:43 PM
bigpulve+'s Avatar
AEed stocks with a retro...
/thread
I had the r34s but I never really liked them. They dont flow right with the 4th gen and just seem wrong.
Old Jan 26, 2008 | 12:50 PM
Mymax97's Avatar
Hi
i love mine the lighting isnt that bad. When i do have my car out on back roads at night its enough light for me to have some fun on the roads. Just aim them alittle higher and youll be fine.
Old Jan 26, 2008 | 10:49 PM
S Cranaw's Avatar
I think I may get them farther down the line, maybe spring. I'll see. I keep debating and cant make up my mind if I want to spend the $$$. Unfortunately, priorities have changed and house shopping is taking precedence over my car. (sad day, I know)
How tough are they (r34's) to install? Do you have to take off the bumper cover at all? From what I've read/remembered it's a few screws here and there and some clips to the grill... is this true?
Thanks for all the feedback guys.
-Steve
Old Jan 26, 2008 | 11:02 PM
kzoosho's Avatar
-Steve
10 mins if you have common sense 20 if your a moron.
Old Jan 26, 2008 | 11:05 PM
S Cranaw's Avatar
Ha! thanks for the confidence boost bro. To be safe, I'll lean to the side of moron and use the 20 mins to do it.
-Steve
Old Jan 27, 2008 | 05:24 AM
yea the r34s are bolt ons...... Just two 10mm screws on both headlights if im not mistaken and splicing the wiring
Old Jan 27, 2008 | 07:55 AM
Mymax97's Avatar
Hi
you dont have to splice any wires. At least i didnt.
Old Jan 27, 2008 | 07:59 AM
kzoosho's Avatar
None whatsoever. It is pnp
Old Jan 27, 2008 | 03:06 PM
accordingtou's Avatar
VQ30 DE T
Clear R34's Definitely PNP I like them I like them alot
Not the best beam pattern though
Old Jan 27, 2008 | 05:28 PM
sorry guys thanks for clearin that up
Old Jan 27, 2008 | 05:41 PM
kzoosho's Avatar
Tell me you knew that already Come on you been around awhile lol
Old Jan 28, 2008 | 06:18 PM
ray_289's Avatar
has anyone else tried the r34s and hids??
Old Jan 28, 2008 | 08:39 PM
BORQUA79's Avatar
nycmaximas member
I like the cefiros better than that beam pattern from the r34s... There isn't too much cutting from what i see on the tutorial... Just find out if its reversible... Thats if after you cut could you go back to stock...
Old Feb 8, 2008 | 07:05 AM
S Cranaw's Avatar
One more question:
For those of you that have the R34's, what are the new bulbs (code/part #) that fit with these headlights.
-Steve
Old Feb 8, 2008 | 07:50 AM
chirp the 1-2's Avatar
i found em on ebay for 140.00 shipped fyi, just tryin to help
Old Feb 8, 2008 | 08:14 AM
kzoosho's Avatar
9005 and 9006 bulbs. I have hids in my r34s now. ou still get the w but you can actually see now. The shield makes it now blind any one also.
Old Feb 28, 2008 | 10:57 AM
GStrength's Avatar
So the black ones seem to present a problem? Well I recently bought the all clear chrome type. They actually arrived today while at work. Is there the same problem as well with the clear chrome version of the r34?
Old Feb 28, 2008 | 12:57 PM
CraigM's Avatar
I like them a lot. just put them in 2 days ago. beam pattern is odd. I would say slightly worse than stock lighting, but the high beams are better. i got the set that came with side markers.
note on the sidemarker install: it didnt come with the little **** that is threaded on on side and pops into place on the other. I had to use my old ones, but the threaded side (side that screws into the back of the side marker) was too small. i took a bic pen and and a heat gun, melted it down and filled in the hole on the sidemarker. let it cool off and redrilled the hole to the size i needed, screwed in the little bastard. that was the only thing that kept my install from taking 20 minutes
def worth it though. looks amazing with the red paint
Old Feb 28, 2008 | 01:54 PM
-Steve
Steve,
IMO, the lighting abilities was noticeable worse than OEM. I opted for the S2K projector retrofit to fix that problem.
Old Feb 29, 2008 | 06:33 PM
machinehead's Avatar
Steve,
got pics of them in action?
Old Sep 8, 2008 | 10:15 AM
caudio51's Avatar
Is there a write up on the cefiros? Also, what's the best vendor to get them from?
Old Sep 8, 2008 | 10:18 AM
JSMax's Avatar
Sold
best vendor is the one with the best shipped price.
imho.
Old Sep 8, 2008 | 10:30 PM
indeep's Avatar
hey guys..i was looking at some headlights for my 99 max and i found this on ebay...
http://cgi.ebay.com/ebaymotors/95-99...6958QQtcZphoto
just wondering if i should get it..because i need some nice light and this uses h4 bulbs i dont know if the light output would be good with these housing...please let me know thanks...
Old Sep 9, 2008 | 06:58 AM
JSMax's Avatar
Sold
those are the "cefiro" headlights. There is plenty of information on this board about how those fit. If you can deal with poor fitment meaning you will need to stick an extra piece of weatherstripping to get a decent fit. Light output will be better than r34 but not as good as stock.
As for if you should get them... it's your money do as you see fit.
Old Sep 9, 2008 | 12:24 PM
indeep's Avatar
well there's no point of me getting these headlights then..if the stock light output is better...i want something nice but the only way is to retro them but i have no clue about that..and it will cost me more for projectors...etc....
i don't know why they don't got any projectors for 99 max...
REDinLV
Aug 15, 2024 12:30 AM
doctorpullit
Oct 28, 2019 10:58 PM
doctorpullit
Mar 29, 2016 11:08 AM
Noela
Sep 26, 2015 08:22 AM
