HELP!!! no power in rear driverside door
Old Jan 27, 2008 | 08:20 PM
jpn's Avatar
jpn
i have no power in the rear driverside door. i dont know what is wrong with it but the power door locks on it dont work nor will the window go down. im not sure what it is but my friends 97 altima is the same. has any one had a problem with this. i want all 4 of my doors in working order thanks guys
Old Jan 27, 2008 | 11:13 PM
pmohr's Avatar
No more Maximas...
Have you actually checked for power with a multimeter?
Checked the wiring?
Checked...anything?
Old Jan 27, 2008 | 11:17 PM
vqmaxman's Avatar
Check the electricals than check If you need a new window regulator switch. If you have a child safety lock check that also.
Old Jan 28, 2008 | 12:52 PM
jpn's Avatar
jpn
i dont believe it is the switch nor child lock because i can open close and lock/unlock manually and i have not checked with a multimeter yet but all of my other doors work fine
Old Jan 28, 2008 | 01:58 PM
pmohr's Avatar
No more Maximas...
Do that, then come back.
Old Mar 24, 2008 | 10:56 PM
tsaulz's Avatar
I have the same issue w/ my front passenger's side door. Let me know if you're able to figure out the cause.
Old Mar 25, 2008 | 01:20 AM
goldtooth's Avatar
Cause is laziness.
/thread.
Better yet, let me telepathically communicate with your maxima so things can work again... right...
Old Mar 25, 2008 | 11:02 AM
tsaulz's Avatar
Originally Posted by goldtooth
Cause is laziness.
/thread.
Are you serious? You aren't funny, and if you aren't able to give useful suggestions, get out.
Old Mar 25, 2008 | 11:24 AM
goldtooth's Avatar
You better believe I'm serious.
I never intended to be funny so go do some work son, now if you'll excuse me I have a harness to make for my full 3.5 swap, hmmrrffppp.
Old Mar 25, 2008 | 11:28 AM
tsaulz's Avatar
I never intended to be funny so go do some work son.
Kind of hard to do when the car is 100 miles away. That's why it'd help for someone to narrow it down so I can relay the information to my less experienced brother who's driving the car.
If you weren't trying to be funny, then what was this weak line about?
You need to grow up, son.
Old Mar 25, 2008 | 11:47 AM
tsaulz's Avatar
Now if you'll excuse me I have a harness to make for my full 3.5 swap, hmmrrffppp.
No need to be excused; you were never invited. And I'm not interested in hearing about your projects.
Now, let me go finish putting back together my brother's car in which I just finished a 6spd swap.
Old Mar 25, 2008 | 01:23 PM
tlrmax's Avatar
Did you take the door panel off b4 this problem started? The window plug may have gotten disconnected. I would remove the door panel and then start investigating or actually your bro will have too. At least the window is up. Its strange that both dont work. If it was a window motor then only the window will not work. It sounds like a harness is unplugged.
Old Mar 25, 2008 | 01:32 PM
tsaulz's Avatar
To my knowledge, the door panel wasn't taken off, but I'll have him check out the connections. I'll also have him check the fuses, because I think the two might be on the same circuit.
I appreciate your help--thanks a lot.
Old Mar 25, 2008 | 02:32 PM
tlrmax's Avatar
It wont be a fuse because all the windows share the same fuse so then none of the windows would work.
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
delerium75
Aug 19, 2015 11:08 AM
kjm900r
Aug 5, 2015 07:14 AM
