Lights are out....help!
Old Oct 27, 2001 | 07:31 PM
RPalka
Tonight I went into my car and as I turned on the headlights my gauge, radio and climate control lights did not light up. However the seatbelt light on the gauge, plus the radio and climate lights lit up when the headlights were off. Therefore when the headlights were on nothing else worked.
Could I have blown a fuse, if so what one and how would I replace it. I need to drive tonight but I can't cause I can't see a damn thing.
Any help is appreciated.
98 SE
Old Oct 28, 2001 | 12:48 AM
Chunger's Avatar
My other car is a Hybrid
Re: Lights are out....help!
98 SE
Try looking for a blown fuse in the fuses boxes tomorrow in the light...obviously start with the more obvious ones like lights, etc... good luck
Old Oct 28, 2001 | 12:50 AM
krzymax's Avatar
Maxima owner since 2000
Re: Re: Lights are out....help!
did you check the dimmer to see if you accidently touched that?
Old Oct 28, 2001 | 06:47 AM
SizosDotCom's Avatar
Re: Re: Re: Lights are out....help!
ROFLMA!!! No response, I guess he found the problem!
Don't worry, happens to the best of us!
Old Oct 28, 2001 | 07:00 AM
RPalka
Got it!
I checked all of my fuses and all are in working order. I then took out and disconnected my dimmer switch and it "smelt" funny. Kind of like a burnt smell. I reconnected it and amazinly it worked. But I am sure that sometime soon I will not be as lucky and the dimmer switch will blow out. How much do they run?
This was a great use of the daylight savings times.........
Old Oct 28, 2001 | 09:10 AM
Chunger's Avatar
Re: Got it!
Did you just have alarm put in? Running a 12V (for the flashing lights) to the wrong wire of the dimming switch will burn it out...
Old Oct 28, 2001 | 10:35 AM
RPalka
Battery Installation
Didn't have an alarm installed however last Tuesday my car died and I needed a new battery. Everything worked fine after that. Could that have been my problem?
RJP
Old Oct 28, 2001 | 04:54 PM
Chunger's Avatar
Re: Battery Installation
RJP
I doubt a dead battery would cause the switch to go out...
Old Jan 22, 2002 | 03:53 PM
max91se's Avatar
dimmer switch
could a dimmer switch be the problem of the gauge and instruments lights not working
Old Jan 22, 2002 | 07:09 PM
nigelcmf's Avatar
Heheh! I've seen the dimmer switchproblem MANY times!
Old Jan 22, 2002 | 08:23 PM
max91se's Avatar
what do you think
I know i am third gen man, but do you think the dimmmer switch is my problem or a is it a fuse?
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
