Took old "aftermarket" wires out and now won't start
Old Feb 23, 2008 | 02:29 PM
Kehops's Avatar
I snipped my dumb grounding wires that I had installed years ago. After snipping them, the car would turn over but wouldn't start. So I took all the bolts out to properly remove all the old wires and while loosening the headlight grounding bolt, it snapped on me. So I wedged the grounding terminal up against the sheet metal to keep it grounded. Then the car started up ok, didn't crank great but started nevertheless. I drilled a new hole in the sheetmetal and got another bolt to re-ground the headlight properly. After I finished I tried starting it again expecting to have no problems but the car wouldn't crank and when I took the key out, the dashbord lights stayed on and my elec. windows still worked...very weird. I tried sanding the terminal down to get a better connection but didn't change nothing.
My guess is it shorting out but I know nothing about this kind of stuff. Anyone have any ideas? Thanks
Edit: The only way I could get my dashboard lights to turn off is by disconnecting the battery. I then reconnected it and tried it again, same problem.
Old Feb 23, 2008 | 02:32 PM
pmohr's Avatar
No more Maximas...
Still on the original ignition switch? They're a relatively common part to go bad in the A32, and stuck contacts in the ignition switch would explain the car staying in IGN after you removed the key.
Old Feb 23, 2008 | 02:41 PM
99MaxSEKH3's Avatar
Is that why sometimes I have to juggle my key to get it to start? I actually came on here to ask that question but had to make 15 posts
99MaxSEKH3's Avatar
oops, sorry I meant Jiggle
Old Feb 23, 2008 | 02:47 PM
pmohr's Avatar
No more Maximas...
Yes, that's another symptom of a failing ignition switch.
~$30, 10 screws, 2 bolts, 15 minutes and you're done.
Search around for the installation instructions.
Nissan part number 48750-1E411, when I looked around for one a year or two ago they were not only the cheapest (vs auto parts stores), but they were the only ones to actually have it in stock.
Old Feb 23, 2008 | 02:50 PM
99MaxSEKH3's Avatar
Oh wow that is awesome thank you very very very much for your help! I actually try to always use nissan parts on my car anyways, so geuss i will call the dealer on monday and let you guys know how it goes, thanks again pmohr your very nice unlike some people on here, they should make you one of those moderator people if you arent allready
Old Feb 23, 2008 | 02:52 PM
pmohr's Avatar
No more Maximas...
No problem, I try.
Moderator, eh? Heh, if only.
Old Feb 23, 2008 | 03:35 PM
JSMax's Avatar
Sold
Originally Posted by pmohr
No problem, I try.
it's mostly a volunteer position....
Old Feb 23, 2008 | 03:41 PM
pmohr's Avatar
No more Maximas...
Given the chance, I'd have no problem volunteering
I've already got sponsor status on my350z (http://www.my350z.com/forum/member.php?u=87414), being a mod would be nice. Definitely clean up a lot of these crap threads in here...
Old Feb 23, 2008 | 09:27 PM
JSMax's Avatar
Sold
what you mean your tired of all the "what intake" & "which exhaust" threads?
There's gold in those....
I also would have no problem volunteering as a mod on this forum. I'm on here every day anyway.
Old Feb 24, 2008 | 08:44 PM
d1max2nv's Avatar
well did you disconnect the bat. before you decided to weld? If not the welder sent a feed back somewhere... good luck...
Old Feb 24, 2008 | 08:49 PM
pmohr's Avatar
No more Maximas...
I don't see any mention of welding in this thread
Old Feb 24, 2008 | 09:48 PM
Hammy
404
Welding Mention Not Found
The Frye
Sep 2, 2021 11:03 AM
boomerbrian
Oct 31, 2018 10:25 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
trungg86
Sep 4, 2015 04:58 AM
crazyespn
Sep 3, 2015 01:30 PM
