CB radio static noise common in Maximas?
Old Feb 29, 2008 | 07:19 AM
Justaguy's Avatar
Hi,
I just installed a 510 cb radio with the K40 antenna..when the car is on and idling I get too much static noise...when I shut off the car, the static is gone...my a.m. car radio is never this bad.
I checked all connections and everything seems fine..It was also grounded. Any clues?? Or are these maximas just "noisy"?
Old Feb 29, 2008 | 07:20 AM
NmexMAX's Avatar
dot dot dot ...
I only get it on my FM when there is a nearby running radar.
Old Feb 29, 2008 | 07:34 AM
Kadantsev's Avatar
Not nessesarily a bad thing then, no?
Old Feb 29, 2008 | 07:58 AM
JNCoRacer's Avatar
Just the tip.
Wouldnt it have been cheaper and less problematic to get a cell phone?
Old Feb 29, 2008 | 08:01 AM
LeVeL's Avatar
Play around with squelch (or whatever that **** is called) maybe?
Snypa's Avatar
huh....well maybe he really wants a radio.no bills to pay end of month.
Old Feb 29, 2008 | 08:02 AM
LeVeL's Avatar
Completely different devices used for different purposes.
Old Feb 29, 2008 | 08:16 AM
Justaguy's Avatar
exactly.
Old Feb 29, 2008 | 09:52 AM
CraigM's Avatar
where do you mount your antenna??
smokey and the bandit music starts playing....
Old Feb 29, 2008 | 09:58 AM
LeVeL's Avatar
I had a small window-mounted antenna that worked just fine:
Old Feb 29, 2008 | 10:29 AM
Justaguy's Avatar
It's a trunk mount..at the middle.
Old Feb 29, 2008 | 10:56 AM
sparkyssb's Avatar
You may want to try heavier gauge wire for your power. Also, perhaps a suppressor would help: http://www.www.premiere-electronics.net/store/cbnf.html. Lastly, make sure to run your antenna wire away from other wires in the car.
Old Feb 29, 2008 | 11:52 AM
Justaguy's Avatar
Thanks sparky...but I hope it's more that just a filter...I have a ANL (noise reduction) switch on my 510 already....I guess this plugs into my fusebox and the cb radio into suppressor.
Yes, the wires run along the passenger side with no other wires.
Heavier gauge wires?? hummm..didn't think about that one. I just used the little thin wires that came with the unit. Think that will make a difference?? (I would hate to re-write the dam thing again).
Thanks!
Old Feb 29, 2008 | 12:23 PM
CraigM's Avatar
okay, before i was just thinking it would be kind of silly to have a cb radio, than i realized i dont even know what you would need one for, so I am asking:
what do you use your cb radio for? over.
Old Feb 29, 2008 | 04:14 PM
LeVeL's Avatar
I got my cb mostly in order to coordinately group drives better. The other thing I used it for was to listen to truckers (sometimes they warn you about cops)
Old Feb 29, 2008 | 04:38 PM
2theMax77's Avatar
adding to sparky, make sure you have a good ground also. most of the time, static and that buzzing noise when you car is running is "dirty" power. i dont kno where u are getting ur power from, try and get it from the fuse box where more power is available than just the cig lighter. also better power will allow ur signal to transmit the furthest it can.
+1 for group drives, lot better than cell phones for talking to a group and no chance of a ticket.
Hondarydr
Dec 30, 2024 06:15 PM
CRizz
41
Jun 7, 2021 05:42 AM
Maxilano
Aug 31, 2015 07:33 PM
MikesChevelle
Aug 9, 2015 11:50 AM
kirkhilles
Aug 8, 2015 10:53 AM
