Time to clean my K&N again... oil Spray or not to oil spray?
Old Mar 3, 2008 | 08:05 PM
S1cTech's Avatar
So this is the 2nd time I am gonna be cleaning my K&N short ram, it is in need of cleaning imo... Last time I cleaned it was about 15K ago and it looks pretty dirty(and it has some battery power corration stuff on it....
Now I used the K&N cleaning kit you can buy for it the last time, but I heard on here a while back that the oil that the kit uses is bad for your MAF... Now it makes sense in a way, but how bad could it be? I mean, I don't soak it, but I coated it in even sprays and it has been done wonders like mentioned in the instuctions...
but if it is bad... why would K&N, a company that knows perfromence and cars, sell something that could degrade or ruin an important sensor in your car?
Now, and I wondering if I should clean it with just a the cleaner and not spray it with the oil stuff it comes with... The last thing I need is a MAF to go by the oil residue.
I mean after all, the oil just acts as a tack for more dirt coming though... Eventhough K&N claims the oil gives a little bit more HP(which I doubt)
Old Mar 3, 2008 | 08:56 PM
Mxrider52's Avatar
I support for what?
There is no problem with oiling the filter in fact you have to oil it otherwise dirt will get through to your motor.
The only reason peoples MAFs get messed up is because they over oil the filter.
Old Mar 3, 2008 | 09:21 PM
99grnmaxgxe's Avatar
/thread
Old Mar 4, 2008 | 12:10 AM
S1cTech's Avatar
yah, See that is what I thought... What are noticable changes in a gen 4's perfromence other then an SES light if I mess my maf up with too much oil?
Anything I should look for? I need to clean my maf and iacv anyway... When I get around too it...
Old Mar 4, 2008 | 06:29 AM
NmexMAX's Avatar
dot dot dot ...
The car will run like crap, stutter & stall.
Old Mar 4, 2008 | 11:16 AM
jacobmh's Avatar
Hve to oil it or you will get dirt jsut do not use tooo much follow the directions and everything should be ok. Make sure you dry the filter well before you oil
Old Mar 4, 2008 | 02:53 PM
max95q's Avatar
Just dont spray the hell out of it. Ive had no problems oiling my K&N filters. More doesnt always equal better.
Old Mar 4, 2008 | 03:00 PM
S1cTech's Avatar
ha, yah, that is what I thought... but I just wanted to know minor differences from too much oil getting all over the maf
Old Mar 4, 2008 | 05:47 PM
njmaxseltd's Avatar
Over 100,000 miles on my K&N, it gets cleaned & oiled every spring.
MAF sensor gets cleaned too, never had a problem.
Always use the oil, the filter doesn't work without it.
Old Mar 4, 2008 | 06:16 PM
Zygi's Avatar
just a question guys
Can you use a cleaning kit which is non K&N ?
Also my K&N is a bit busted at a spot where it is rubbing a little against the battery cable. I have to sort something out so that the filter is not rubbing anymore. But if I keep on driving with that "bruised" filter do you think that would eventually have an effect on the MAF ? And therefore should I get a new filter right away or just clean the old one and reuse it?
Old Mar 5, 2008 | 03:54 AM
S1cTech's Avatar
If it is a cotton type then yes, I would not see an issue, but if it s a paper type... then NO.. DO not do it... IT will ruin it and make it worse for air flow.
Old Mar 5, 2008 | 08:36 PM
jrsy2003's Avatar
i was about to buy a new filter not knowing you could clean it
MatthewsMaxima
Sep 11, 2015 03:21 AM
doobadoo
Aug 15, 2015 06:43 PM
jchronis2552
Aug 13, 2015 07:48 AM
Balkins
Aug 12, 2015 06:39 AM
