Fuel smell from injectors under the IM?
Old Mar 7, 2008 | 08:55 AM
Mctwist77's Avatar
Hey guys I get the fuel smell from my vents when my car is idling. I checked it out today and it wasnt coming from the fuel filter. It was coming from the area under the Intake Manifold where the knock sensor. It smells like it might be from one of the injectors. There is no fuel spilling out but I can smell it. What could be wrong? Leaky injector?
Old Mar 7, 2008 | 09:43 AM
Blackwind's Avatar
yep. park it for a few days if you can and start sourcing parts.
Old Mar 7, 2008 | 10:01 AM
Mctwist77's Avatar
Just new fuel injectors and O-rings?
Old Mar 7, 2008 | 10:02 AM
Mctwist77's Avatar
Will it be safe to drive for a while?
Old Mar 7, 2008 | 10:21 AM
Tatanko's Avatar
Bacon Lover
If you keep driving it, it could become worse if it is indeed a leaky injector. Hard to tell whether it is the injectors themselves or one of the two sets of o-rings or what (for the record, there are o-rings on the actual injectors and there are big fat o-rings that the injectors themselves sit in in the lower manifold).
Old Mar 7, 2008 | 11:28 AM
sparky1562's Avatar
Well mine was the hose on the high pressure line between the front and back injector rail. Might check that first. Mine did not leak unless it was cold out. See if it is loose, can you twist it around.
Old Mar 7, 2008 | 02:36 PM
Mctwist77's Avatar
Yeah I got the smell before school when it was about 30 degrees out. Then after school it was about 45 and I couldnt get the smell to come back.
Old Mar 7, 2008 | 03:33 PM
Blackwind's Avatar
you got a spare car? this is a good time to learn how to remove your intake manifold and injsctors. fun stuff really.
Old Mar 7, 2008 | 04:00 PM
mad greek's Avatar
The clamps at the hi pressure fuels line are the most common cause of that problem during cold weather. The hoses have been compressed so long there no longer flexable & seep fuel when cold.So its hoses & clamps to do it right.
Old Mar 8, 2008 | 08:06 PM
sparky1562's Avatar
I had put new hoses and clamps on when I replaced the injectors at 183K. In my case, I guess I just didn't get it on perfect and it took a while to start leaking.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
