Knock Sensor Reset
Old Mar 7, 2008 | 09:21 AM
rhonster's Avatar
Knock Sensor Reset
after replacing the knock sensor, is the basic screwdriver reset of the ECU sufficient to activate the new ks or does it need an electronic interface?
1997 SE standard shift.
thanks.
Old Mar 7, 2008 | 09:28 AM
maximabebe's Avatar
Just reset the ECU.
Old Mar 7, 2008 | 09:30 AM
HobHayward's Avatar
I didn't even have to reset mine, I went to check the codes and it took care of itself.
Old Mar 7, 2008 | 09:33 AM
rhonster's Avatar
do you have any install tricks for the sensor itself? i know its a 12mm and my hand is not huge, but I am still stuck.
Old Mar 7, 2008 | 09:35 AM
HobHayward's Avatar
Use your left hand-- it'll be easier to get in there.
Old Mar 7, 2008 | 09:43 AM
ROCKART's Avatar
wants an I35
just get someone with small arms to stick their hand down in there and loosen the nut.
Old Mar 31, 2008 | 08:47 PM
rainman_ca's Avatar
KH3 5spd
+1 with that and it didnt even take ten minutes. had my younger bro to help out.
Old Apr 1, 2008 | 05:07 AM
Allens96SE's Avatar
depending on your tool box... if you use a couple of swivel sockets and couple extensions you can fanagle a 1/4 ratchet socket setup in there pretty easily.
my03maxima
Jul 28, 2024 07:40 AM
gigabyte
Jan 6, 2017 06:05 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
