Wooden trunk liner
Old Mar 12, 2008 | 12:07 AM
$EXY BLAXIMA's Avatar
Wooden trunk liner
Hey guys, anybody know where i can get the wooden trunk liner for my max as mines warped and ultimately destroyed. Or better yet, does anybody know what else i can use that might be stronger then that? Thanks in advanced for your responses.
Old Mar 12, 2008 | 12:18 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Buy some 1/4" particle board from HD and use yours as a template to cut out a new piece.
Old Mar 12, 2008 | 06:37 AM
mowgli29's Avatar
Horizontally opposed.
http://forums.maxima.org/showthread....ht=trunk+saggy
It sits on top of your spare tire, so if you don't have your spare tire in...you'll have to rig something up. I just put three legs on it, works great!
Old Mar 12, 2008 | 06:44 AM
Thanatos's Avatar
i would use 1/4" luan. i did in my sentra and it worked perfect. particle board will not hold to any abuse or moisture if ever any.
Old Mar 12, 2008 | 09:52 AM
Thanks for the responses, i'm willing to try anything as i have nothing in there right now!
Old Mar 12, 2008 | 01:29 PM
WildMax87's Avatar
as stated before u can use your old one as a template or like in my case if yours is too f**ked up then u can use the thin piece of carpet cut it exact then trim off the corner of the right side. u do this because it wont go in if you have it exact...then once you get it fitted right staple the carpet to the wood around the edges and boom OEM BISHES!
EDIT: btw if you are planning on putting subs in your truck go ahead and take out your spare and throw a big sheet in the well...you wont be able to get it out anyways and its just more weight
REDinLV
Aug 15, 2024 12:30 AM
mrgooch
Sep 21, 2015 08:43 PM
lux97Max
Sep 14, 2015 07:07 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
