Boring out throttle-body?...
Old Oct 30, 2001 | 05:02 PM
Vyrus's Avatar
My mechanic said I should bore-out my throttle body for maximum performance out of an intake. Why have I not seen any .Orgers do this? Is it expensive or just impossible on a Maxima?
Thanks,
Cyrus
Old Oct 30, 2001 | 05:11 PM
98sterlingmist's Avatar
no real gain from this
Old Oct 30, 2001 | 05:13 PM
Vyrus's Avatar
Why?...
Can ours not be widened or is it big enough already?
Thanks,
Cyrus
Old Oct 30, 2001 | 06:47 PM
BRIGBOY's Avatar
I think it can't get much bigger,
and it could get costly.
I was lookin in my dads Tahoe magazine, ( every aftermarket part imaginable is available for it ), and the bigger throttle body was $499, claiming a 5-10 horse increase which I think is BS. So thats about what you'd be lookin at for minimal if any gains. I'm sure its worth it if you go bore happy with some other parts though.
Old Oct 30, 2001 | 07:26 PM
Bags's Avatar
VG Ridah's Biatch Hoe
extrude honed is what i have seen doing some searches. what i have found is do the TB and INTAKE manifold.
Maybe a bigger diameter TB. not just a bore but like 1/2 inch bigger?? my 2 cents
Old Oct 30, 2001 | 08:33 PM
got rice?'s Avatar
it'll yield gains but it's not worthwhile unless you open up the rest of the intake flow (port/polished upper intake plenum OR extrude honed, more aggressive cams, valve/head job, etc)
Old Oct 30, 2001 | 10:28 PM
party_boy's Avatar
hmm maybe try to gut one from a 2k+
if i remember right they had two new things 1. a new tb and plumbing, and 2. the bypass valve on the exhaust. If it fits great.
Try that
Old Oct 30, 2001 | 10:29 PM
fnkmaster's Avatar
moreover if you have no boost then wuts the point. from what i've read about this, minimal gains are produced na, but the most is seen only if u go the forced induction route. still it is something to think about.
Old Oct 31, 2001 | 03:58 AM
got rice?'s Avatar
This is one of the misconceptions floating around on the forum.
How do you make more power? By bringing in more air (and adding more fuel, spark, and compressing it). By freeing up the exhaust-side of the system, you allow more air to be pumped in. By freeing up the intake-side of the system, you allow more air to be pumped in.
THe above mentioned parts will increase the flow into the combustion chamber. Due to the 3.5L nature of the engine, gains will be generally better than a 3.0L engine. I have no clue what the intake and exhaust plumbing looks like yet but knowing Nissan engineers, there are definately area for improvements.
It's not cheap but if you want XXX hp via all motor, it is possible.
Old Oct 31, 2001 | 08:25 AM
dwapenyi's Avatar
Think about this;
The maxima, when it went from Gen4 to Gen5 went from 190 to 227 hp. Did the throttle body increase in size?? Don't think so. The limiting factor seems to have been the intake manifold. So, if you increae the throttle body size, you've still got the bottleneck from the intake manifold.
DW
Old Oct 31, 2001 | 10:15 AM
fnkmaster's Avatar
pardon my ignorance, but i was talking about just the throttle body. i agree with what got rice? said, maybe i should have taken out the quote before replying
jerrod99_se-l
Sep 25, 2015 03:02 AM
followthadollar
Sep 23, 2015 08:31 PM
