Is a 42 pound rim and tire, too much for the max?
Old Mar 25, 2008 | 01:59 PM
Mctwist77's Avatar
Hey looking to get some rims but they weigh 42 pounds each. So my question is will they hinder my performance? And will they put wear and tear on my tranny? Should I just wait and buy some OEM 17's?
Old Mar 25, 2008 | 02:39 PM
emoore924's Avatar
42 lbs ea? What are they made out of, granite I think that's pretty heavy. And would you have to add the weight of the tire to the 42lbs? If so, you're probably something like 65-70lbs a corner. IDK the spec/limit but that is an awful lot of unsprung weight at each corner. You might want to consider something else.
If it helps, tire rack has tire weights on their website (and probably wheel weights too for the wheels they sell). You might want to do a few back of the envelope calc's to figure out how much weight diff you're talking about between factory wheels and the 42lb ones. If it helps to know the weight of a bare factory 98 se wheel, I have a set in basement I can check. Ping my email and ask, and I'll take a look.
Old Mar 25, 2008 | 02:41 PM
tbergma1's Avatar
5zigen sells a 17 inch rim that weighs 15.5 lbs.
Jeff92se's Avatar
I'm needing a caw
Rims=42lbs? God dam son.
Rims + tires = 42lbs. Pretty respectible.
Old Mar 25, 2008 | 04:10 PM
JtzMax's Avatar
Whatchyou say?
but still Jeff .... that much? seems like a lot to me!
oh ... i know, it's that 30 lb valve stem cap!
Old Mar 25, 2008 | 04:13 PM
Jeff92se's Avatar
I'm needing a caw
for 15s = heavy
for 16s = heavy
for 17s = okay
for 18s = not bad
for 19s = pretty light
Old Mar 25, 2008 | 04:14 PM
LeVeL's Avatar
42lbs each rim? Thats a LOT, imo
Old Mar 25, 2008 | 04:24 PM
JtzMax's Avatar
Whatchyou say?
wow ... just seems like a lot for an aftermarket rim at 17" (to me anyway)
Old Mar 25, 2008 | 05:13 PM
Snypa's Avatar
thats alot...people on here be complaining about 24lbs..end of story.
Old Mar 25, 2008 | 05:42 PM
z32drifter's Avatar
If you are talking about the combo weight wheel+tire, that's close to the stock weight. The 215/55/16 is going to be 20-25lbs and the stock SE 16s are about 20lbs. Combine the stock wheel and tire and your at 40-45lbs.
Old Mar 25, 2008 | 06:36 PM
MrDicks95SE's Avatar
Offset Is Everything.
i had 18x9's and with tires were about 50lbs. freakin boat anchors...
Old Mar 25, 2008 | 06:55 PM
Mctwist77's Avatar
Hey guys thanks for all the input. They are 18's and that weight it the wheel and tire combined. They are called ADR spades.
Old Mar 25, 2008 | 07:28 PM
Crusher103's Avatar
that makes sense i got Enkei RP02-J 17x8s with tires weigh around 50lbs on a bathroom scale and those wheels are pretty light,
tires are fat and need to go on weight watchers
Old Mar 25, 2008 | 08:44 PM
EnervinE's Avatar
i has college
Yeah tires are surprisingly heavy...my rubberband 235/45/18s are like 22lb each. Combined with the 27lb muranos...yeah. Like mr****s said, boat anchors.
Old Mar 25, 2008 | 08:51 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Nearly half the people in this thread think he's asking about the wheel weight alone
Old Mar 25, 2008 | 08:54 PM
MaximaSpd85's Avatar
i think its ok, the stock 16 inch SE wheels+tire that i had weighed right at 44 lbs or so....according to my bathroom scale.
Old Mar 26, 2008 | 03:49 AM
Mctwist77's Avatar
Really? Wow the stock SE rim and tire is that much????!!
Old Mar 26, 2008 | 06:08 AM
IlyaK's Avatar
The Golden One
Yeah the stock SE rim is about 17-18lbs I believe...couple that with a 24lb tire and you get 42.
Old Mar 26, 2008 | 06:11 AM
zelot
a 42 rim will hurt your braking, acceleration and gas mileage. i would aim for under 50 including tire weight, but even that is a big sluggish.
Old Mar 26, 2008 | 06:13 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Thanks for your contribution, ROCKART.
Old Mar 26, 2008 | 06:34 AM
IlyaK's Avatar
The Golden One
^^^ lol.
Old Mar 26, 2008 | 06:40 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by IlyaK
^^^ lol.
I'm pretty sure he wasn't joking, and was complimenting him on an informative first post.
42lb wheel/tire combo is VERY good.
Old Mar 26, 2008 | 07:07 AM
maxboy325's Avatar
I agree to both statements
Old Mar 26, 2008 | 07:39 AM
KRRZ350's Avatar
Ok, for future reference.........
rim = rim
tire = tire
wheel = rim + tire
Old Mar 26, 2008 | 08:15 AM
99grnmaxgxe's Avatar
I like the OEM rims better.
Old Mar 26, 2008 | 08:27 AM
hot_wax_tree's Avatar
rim = rim
tire = tire
wheel = rim + tire
um sorry man first off way to be descriptive. "rim =rim"???
Second a wheel is what you call a rim
wheel + tire = wheel + tire.
Dont confuse people you will **** others off.
Old Mar 26, 2008 | 08:43 AM
mowgli29's Avatar
Horizontally opposed.
thank you, I agree.
rim=stupid word that should never be used IMO. Just call it a wheel!
and a wheel is not a "rim + tire" it's a wheel.
Old Mar 26, 2008 | 08:45 AM
Mctwist77's Avatar
So after reading your opinions it seems pretty split up.
Old Mar 26, 2008 | 08:51 AM
ROCKART's Avatar
wants an I35
i got some 2002 SE wheels on my 97, upgrading from the stock 15 inch sawblades. i felt a HUGE difference in pull off the line, as well as braking. plus now, after a couple of weeks, im noticing a 20-30 mile-per-tank drop. they look great, but my performance has suffered too much....
the stock 15 inch sawblades weigh 16.5 lbs
the stock 17 inch SE alloys weigh 24.5 lbs
im going to be selling them soon and gettin some 14 lb 17" Koseis.
Old Mar 26, 2008 | 09:16 AM
mowgli29's Avatar
where are you buying koseis?!?! I wanted some, but tirerack didn't have 17x9's and I couldn't find any!!!
and yes 42lbs is pretty good. My combo is about 44-45, but I'm ok with that since they're 17x9's with 255s
Old Mar 26, 2008 | 09:39 AM
RacerX1320's Avatar
My stock 15 inch steelies with all seasons 41 pounds.
After market forged 17x8s with tires 34 pounds.
What wheel and tire is it ? <--- MIND YA BITNESS.
Old Mar 26, 2008 | 10:07 AM
it's not only the weight of the wheel that matters you are adding a wider and larger wheel. the force needed to move the wheel is staying the same yet the 17's are needing more force to move. so there fore you are slower and have worse mileage.
But good luck with thos Koseis
Old Mar 26, 2008 | 10:15 AM
wider tires = larger contact patch = more rolling resistance BUT better grip, especially on high HP cars.
Old Mar 26, 2008 | 10:46 AM
Mctwist77's Avatar
The wheels are ADR Spades? Anyone ever hear of ADR, is that a reputable name?
Old Mar 26, 2008 | 11:12 AM
BIFF
yea ive heard of adr. i think there are a couple of them for sale in the classifieds
MR2 T'd
Jul 9, 2021 05:06 AM
captchaos
Mar 15, 2016 12:18 PM
Maxima.KsA
Sep 8, 2015 11:33 PM
MaxLife17
Sep 8, 2015 02:36 PM
jfl330
Sep 4, 2015 01:44 PM
