A/C freeon?
Old Mar 27, 2008 | 10:20 AM
jav24's Avatar
A/C freeon?
hy i have a 96 maxima gxe and the maxima was involved in a car accident and i had to replace the ac condenser so my ? is where do i install the freeon for my ac is it the line next to the ac condenser one with the light blue cap ?
also are those r34 freon botles that also seals the leaks and sell in auto zone are good ?
Old Mar 27, 2008 | 05:01 PM
pmohr's Avatar
No more Maximas...
The A32 system does not use Freon, it uses R-134a.
If you replaced the condensor, you need to take it to a shop to have the system recharged, as it needs to be evacuated first. Without a vacuum pump, you can't evac it yourself.
Old Mar 28, 2008 | 06:45 PM
Xzecution'R's Avatar
if he was able to change his condenser then his system is empty. just tell the shop you take it to to put oil in it and charge it. i hope you didn't have the a/c in open atmosphere for more than a day. otherwise you'll have to change your filter as well.
Old Mar 28, 2008 | 07:11 PM
pmohr's Avatar
No more Maximas...
Yes, his system is completely empty, and holds atmospheric pressure. Therefore, an evac is needed.
Not sure what you're trying to say here, maybe you're confusing evac and recover?
Old Mar 29, 2008 | 03:49 PM
Mad Medicine's Avatar
you need specialised equipment for emptying/filling ac systems. the Evac people are talking about here is putting the ac under vacuum for awhile to suck all the moisture out of the system and air, and the machine refills it afterwards without disconnecting (same machine that does all this). also if the system was open forawhile, you might need to change the filter like the guy here sujested. best is go ahead and bring it to an ac specialist and tell him what you changed and what he recommends to do, or if he thinks everything is alright and can proceed by doing vacuum/refill.
BkGreen97
Apr 2, 2016 05:47 AM
Turbonut
46
Oct 21, 2015 08:28 PM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
EdRomo86
Sep 12, 2015 07:49 PM
