DIY: Oil pressure switch?
Old Mar 28, 2008 | 08:11 AM
jim84's Avatar
I take it replacing my oil pressure switch is easy, since my mechanic said he can do it (p/l) for $95. Is this something I can do fairly quickly? I'm a beginner-to-intermediate mechanic.
How long will it take me? I have to leave town tonight at 8:00---no later!
Thanks for any helpful hints.
Also---is replacing the boot and bushings of the rack & pinion hard? Gonna tackle that, too.
Old Mar 28, 2008 | 08:18 AM
DrPaulFlammond's Avatar
You can do it. It's a $6 part from AZ. And another $6 if you buy the special socket (why not?)
DIY writeup here.
-DPF
Old Mar 28, 2008 | 08:35 AM
Snypa's Avatar
simple.dont pay $95 to do that.last time i checked it cost $8 at zone and its a disconnect, screw out bad, thread new and screw,screw in good.
Old Oct 31, 2010 | 12:40 PM
Imagination's Avatar
I tried the link above for the DIY oil pressure switch, but the link only takes you back to the main page. Does anyone have a better link?
Old Oct 31, 2010 | 12:52 PM
hornepirate's Avatar
you really dont even need a diy. is it the oil presure switch behind the lower oil pan towards the firewall? i didnt even use a special socket...just a wrench. it took me 20mins to do it
jack up the car, put it on stands, grab some some wrenches unplug it, take off the old one put on the new one.
Old Nov 2, 2010 | 07:17 AM
talisman311's Avatar
make sure to wrap the threads in teflon tape for a good seal
Old Nov 2, 2010 | 07:29 AM
99greddymax's Avatar
hey! this is how shop's make their money!
Old Nov 2, 2010 | 12:18 PM
Swazey's Avatar
do you have to empty the oil to do this?
i have a mechanical oil pressure gauge tapped into where this would plug in. its starting to leak due to a douchey-install and need to fix it but will wait till i have to change my oil if necessary. thanks
Old Nov 2, 2010 | 03:50 PM
most likely it will leak.. i would just wait till you do an oil change.
Old Nov 3, 2010 | 07:49 AM
Swazey's Avatar
figured as much, thanks for the response
Old Nov 3, 2010 | 04:21 PM
tzilla's Avatar
I just got it changed while doing having my oil changed. mechanic charged me 8$ worth it.. he drained the oild for change, replaced the switch, put new filter, refilled new oil
Old Nov 3, 2010 | 04:54 PM
Trapstars's Avatar
they r not hard to replace at all.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
James92SE
Oct 8, 2015 04:57 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
