Replacing axle seal?
Old 03-29-2008 | 04:16 PM
sicivic89's Avatar
I'm trying to replace the driver side axle seal for a 1999 Infiniti I30, which should be the same as a Maxima. I popped out the old seal and am trying to install the new seal. But the seal is not going in straight - it's crooked. Any ideas or tricks that will help?
Old 03-29-2008 | 05:46 PM
dgeesaman's Avatar
Maintenance Monster
If you can't find a large socket that straddles the dust lip of the seal, take your time and gently tap in the seal around the outside. Go slow rotating each tap 120° from the last.
Dave
Old 03-29-2008 | 06:08 PM
chillin014's Avatar
GOOD LUCK. i couldnt manage it and now i'm rebuilding my tranny
Old 03-30-2008 | 06:48 AM
HomerMAC's Avatar
Donating i30 Owner
the seal is easily damaged if tapped too hard.. = ( I learned.. the hard way...
Old 03-30-2008 | 08:31 AM
Nealoc187's Avatar
SLOW
dgeesaman's suggestion of a properly sized socket or a seal installer is your best bet. I've never done a seal install while the trans was on the car but I may actually be trying it today, and for the job I borrowed a seal installer from work which is basically a round flat steel thing that you bang with a hammer to try to evenly distribute the pressure you're exerting on the seal.
vingodine
45
05-21-2016 12:46 PM
kingw323
20
10-21-2015 08:36 AM
Starrider
09-17-2015 07:26 AM
carlosvq30
08-17-2015 11:32 AM
DayHeyZeus
Garage and Workshop
08-16-2015 12:29 AM
Quick Reply: Replacing axle seal?
