RSB + weak chassis = Creak ARGH
So I finally got around to installing my RSB on my 99 i30t and immediately notice the car creaks around corners and uneven surfaces. Now I'm paranoid that this thing is hurting my car and so I don't even corner fast anymore
..... although when I do, the nose does stay in really nice. I was wonderin if any of you guys have had one for a long time if it causes any problems
I would try to pick up some of that chassis lube that I mentioned eariler and lube up the bushings. You would be surprised just how annoying a squeaking sway bar can become. You stated that you didn't have a squeak, you installed the swaybar and now you do. Leads me to one conclusion.
Maybe you are right and your car is falling apart. Sell it to me for $1.00. Thanks.
When I first installed my progress rsb I had this metallic scratching noise when I went over bumps. Turns out that the brackets I had to take off the arm due to the new brackets of the rsb were rubbing against it making the noise. I ended up insulating the metal on metal contact and using large zip ties to secure it. Results: No more noise
Check it out, take the wheel off and move the things around to see if you can duplicate the sound.
Apr 16, 2020 05:15 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
