car shaking around 60 mph
Old 04-06-2008 | 09:51 AM
xkazik's Avatar
My car starts to shake around 60 mph .I bought new tires and i put them in the back ,the tires i had on the back i moved to the front because they were 215 and the new ones are 225, the old tires are only couple of months old so its not them. Its a weird vibration of the car that i cant even tell if its from the back or front . all the wheels are balanced . anyone has any idea what else can cause this ?
Old 04-06-2008 | 10:18 AM
njmaxseltd's Avatar
Have the balance checked again, all four tires. Find a shop that has a road force balance machne. You can google road force and put your location into the web site. It will tell you what shops near you have that balance machine.
Old 04-06-2008 | 10:31 AM
LeVeL's Avatar
Check the tire pressures. Then balance.
Why are you running 225 in the back and 215 in the front? Shouldnt it be the other way around...
Old 04-06-2008 | 10:32 AM
xkazik's Avatar
Just trying to finish the 215 in front then buying 225
Old 04-06-2008 | 10:44 AM
LeVeL's Avatar
throw the 215s in the back and go driftinggg haha
Old 04-06-2008 | 11:09 AM
xkazik's Avatar
would a bad tire cause that ? and how can u check the tire
Old 04-06-2008 | 09:55 PM
beez5spdmax's Avatar
do u have rims or stock rims?
Old 04-06-2008 | 11:33 PM
hot_wax_tree's Avatar
this is by far the stupidest I am a gangsta comment I have ever read....
A wheel:is a circular device that is capable of rotating on its axis, facilitating movement or transportation or performing labour in machines.
Rim:the upper or outer edge of any object, typically some thing circular or approximately circular.
I would say take your wheels off and check for any loose items you may find.
Old 04-07-2008 | 03:54 AM
LeVeL's Avatar
wow, go away
Old 04-07-2008 | 05:03 AM
njmaxseltd's Avatar
Seriously, we all know what "RIMS" refers to when used on an automotive forum.
Old 04-07-2008 | 06:23 AM
Shoto925's Avatar
When I got my max it shaked at 60, I changed front driver and rear passenger and now it doesn't shake till 80 and not as bad
Old 04-07-2008 | 06:35 AM
gatsugansu's Avatar
Dude you know he meant an aftermarket wheels. Don't take it out of context.
Old 04-07-2008 | 10:18 AM
MonsterMaxima69's Avatar
i got a 98 nissan maxima, and it also shakes around 60mph, its not a continuous rumble, but its every 4 seconds.. like a headache lol. i dont think its the wheels, i hope its not the steering mechanism in the steering rod, cuz thats **** could be expensive. let me know if u have same problem, pulsive rumbles.. peace!
Old 04-07-2008 | 10:59 AM
3 point slow's Avatar
I would suggest after checking the balance (that'll also tell you if any rims are bent or whatever), check the wheel bearings.
Ps...by "rims" I mean the upper or outer edge of any object, typically some thing circular or approximately circular.
Old 04-07-2008 | 11:58 AM
Snypa's Avatar
OMG...........i think you should leave.
Old 04-07-2008 | 11:59 AM
Snypa's Avatar
check tire pressure, bent rim,balancing/alignment,axles,busted boots.
Old 04-07-2008 | 12:02 PM
ILL-Maxima's Avatar
I bet it's a bent rim... get them balanced.
Old 04-08-2008 | 06:59 AM
MaXiMa_PrInCeSs's Avatar
Mines does that too i have to get it balance and change the pully on the car that is what my dad said but my pully is broken when you look at it. so i know is that and the balance is way off and i have to replace a axle i know it s alot of work
Old 04-08-2008 | 09:22 PM
ejarmol's Avatar
do you have rims or stock rims?
haha that shyt is hilarious
pretty gay you pasted the definitions in there though buddy#2 who attacked gangster buddy originally and has now added it to his sig
Old 04-08-2008 | 09:36 PM
HAHAHAHAHAH
Old 04-08-2008 | 10:00 PM
u must be bored up in the mountains its not my fault u dont know other automotive slang. hot-wax-tree. what kind of name is that u are a bird
Lakersallday24
06-16-2019 01:35 AM
Finkle
09-27-2015 09:53 PM
Hondarydr
09-08-2015 03:13 PM
jhontelj
08-17-2015 04:07 AM
Gsantos79
08-08-2015 07:41 AM
Quick Reply: car shaking around 60 mph
