Transmisson Leaking where axle goes into tranny. PICTURES!
Old Apr 7, 2008 | 04:36 PM
Mctwist77's Avatar
Ok so I just replaced my axle seal on my drivers side axle and now I have a leak. Could this be the seal? Or is my axle not all the way in? Here is a picture of my driver side axle going into the tranny. It is a slow leak but you can see the moisture in these pics.
Old Apr 7, 2008 | 04:37 PM
Mctwist77's Avatar
Second picture sucks, disreagard that.
Old Apr 7, 2008 | 04:44 PM
sicivic89's Avatar
The axle looks to be all the way in from the first picture. Did the old axle seal leak or did the leak just happen after you installed the new seal?
Did the axle click into the transmission when you installed?
Old Apr 7, 2008 | 05:00 PM
Mctwist77's Avatar
I thought it clicked. I replaced the axle but left the old seal. Then I realized the old seal was bad and I replaced it with the new seal now I have a leak.
Old Apr 7, 2008 | 05:07 PM
RA030726's Avatar
I'm nutty for Nissans
Jiggle the inner cv to check for play in the diffy bearings. You may need a new tranny in the future.
Old Apr 7, 2008 | 05:45 PM
Mctwist77's Avatar
New tranny? Are you serious?
Old Apr 7, 2008 | 06:32 PM
dgeesaman's Avatar
Maintenance Monster
Not new, but in many cases a leaking axle seal is the first symptom to show that 5 speed needs rebuilt.
http://forums.maxima.org/showpost.ph...5&postcount=56
Dave
Old Apr 7, 2008 | 11:19 PM
beez5spdmax's Avatar
i just got my 5spd tranny rebuilt. get ready to start saving some $$$$$ for a rebuild thats how it started with me. axel was leaking
Old Apr 8, 2008 | 03:09 AM
JonBlz's Avatar
a.k.a. STuNtMAN
i had a same problem get the seals from the dealer i replaced my seals everytime i had to change my axle and all
Old Apr 8, 2008 | 10:34 AM
Mctwist77's Avatar
Yeah but the tranny shifts fine and it feels as it should? Could the axle not be all the way in?
Old Apr 8, 2008 | 10:55 AM
Nealoc187's Avatar
SLOW
What do you want people to say? Yes, it could be that it's not all the way in, but from your pictures, as blurry and vague as they are, it appears the axle is all the way in the trans. Thus people are suggesting a differential bearing problem.
You're not going to figure things out by asking hypothetical questions and getting speculative answers based on your hypothetical questions, you need to get under the car and see if it's all the way in there or not. That's the only way you are going to solve this problem.
How your trans feels has nothing to do with anything. Failing differential bearings don't affect the transmission's shifting feel.
Old Apr 8, 2008 | 10:57 AM
kzoosho's Avatar
Now wondering could this be the same on a 2001 vlsd tranny also? Mine is leaking.
Old Apr 8, 2008 | 11:43 AM
ajcool2's Avatar
Its your wheelgap.
Old Apr 8, 2008 | 12:49 PM
Snypa's Avatar
Originally Posted by ajcool2
Its your wheelgap.
Old Apr 8, 2008 | 12:54 PM
Reality sucks's Avatar
hahah.. honestly it doesnt look that bad. i would rec. replacing the seal, and see if the sysmptom returns. like others have suggested. not a big deal and will tell you if there are bigger problems at hand.
Old Apr 8, 2008 | 03:05 PM
dgeesaman's Avatar
Maintenance Monster
As Neal already said, failing diff bearings are silent but deadly. When they really get worn the diff will move around enough in the housing to cause the axle seals to leak. You can change the seal, but if it's the diff bearings it will leak again soon.
You won't feel worn diff bearings when shifting. Sometimes the next thing is damage to the ball bearings on the input shaft caused by the particles of the diff bearings. Sometimes the slop from the worn bearings causes a gear to shred off all of it's teeth. In any case, the next thing after you notice a leaky axle is a very expensive thing.
It looks like your axles is snapped in. You'll know it's in when you pull straight out and the axle won't come out.
My point is you should check for looseness in the diff per the link I posted. Now is by far the cheapest time to learn and address the problem. If you wait too long you will need a new tranny.
Old Apr 9, 2008 | 10:11 AM
Mctwist77's Avatar
Little update. I brought it to my mechanic and he said " on older cars there might be a tiny leak or two that does not need to be addressed right now and you do not have to concerned about the transmission fluid unless there is a steady flow pouring out."
Isn't the slow leak eventually going to lead to no tranny fluid? And that would 100% mean that I would need a new tranny?
Old Apr 9, 2008 | 01:49 PM
dgeesaman's Avatar
Maintenance Monster
Observe common sense. Check the oil level in the tranny every 1000 miles at first, then 3000miles if the level isn't changing much. The important thing is that you never run less than, say, 1/2 quart low. It takes a lot more than the occassional drip to do that.
Dave
Old Apr 9, 2008 | 07:56 PM
Mctwist77's Avatar
Thanks Dave I feel better now. And plus whats the worst that could happen? The tranny goes and I rebuild it.
Old Apr 10, 2008 | 07:49 PM
smai555's Avatar
yes that is where i am at right now it started as a leak i toped it off as much as i could
do u notice a weird noise when the car is at idle then when you push the clutch in its gone?
or your car seems kinda loud when increasing speed?
its a bearing and its getting looser and looser
speaking of which if anyone has a rebuilt tranny shoot me an email smai555@yahoo.com
thanks
PH98I30
29
Feb 10, 2025 12:03 PM
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
