Who sad cleaning throttle body dont help?
Old Oct 31, 2001 | 04:18 PM
190hpKiLLA's Avatar
Granny Driven
Today I cleaned my throttle body. WOW I finally dont haveidle problem. I have a 5spd. My idle is up to700 from 600. When I turn on the lights there is no more vibration and RPM drop. The car runs smoother and quicker. Well lets hope this will continue for a long time. Not just today. Thanks to all who helped me. You know who you are.
Old Oct 31, 2001 | 04:25 PM
Vyrus's Avatar
What do you mean "clean" it?...
Did you polish it?
Old Oct 31, 2001 | 04:28 PM
190hpKiLLA's Avatar
Granny Driven
Re: What do you mean "clean" it?...
Originally posted by Vyrus
Did you polish it?
You clean it by removing the intake and spraying it. Where the butterfly is. That helps your idle and air flow.
Old Oct 31, 2001 | 04:44 PM
bullseye's Avatar
Re: Who sad cleaning throttle body dont help?
I think the comment referred to replacing the throttle body with a larger one, or boring out the throttle body. Cleaning the throttle body is part of a standard preventive maintenance program. I think everytime you go in for 30,000 mile service, they dump a bottle of cleaner in your fuel tank...
Old Oct 31, 2001 | 04:51 PM
matty's Avatar
No, he's talking about acutally taking off the rubber end goin into the trottle body, spraying TB cleaner in there, scrubbing it I guess, and bolting it all back together...I will do this soon cause I have that same idle drop even when I roll down the windows and stop...the stuff that goes in your gast tank is for your fuel system and injecters
190hpkilla...Do I scrub the inside and wipe it down or scrub and just put back together and start ?? give me the process please
Old Oct 31, 2001 | 05:17 PM
190hpKiLLA's Avatar
Granny Driven
Make sure you buy throttle body cleaner for fuel injected cars.
Take the intake tubing off with car off. Spay and clean. Dont spray too much. Scrub, scrub. Move the butterfly around. Put everything back but dont tighten the screws. Start the car. It will have trouble starting. Dont worry its normal. After running for like 5 min. Shut it off. Take everything apart again and this time start the car. Rev the engine a bit and spray for like 10 seconds not more. wait. Rev it and spray again. Repeat this process few times. Dont spray too much as it may cause the catalitic converter to overheat.
Then put averything back and repeat step one until the inside is clean. Dont over do it. 2 times each way is more then enough. Then drive your car around. Good luck
Old Oct 31, 2001 | 06:37 PM
Eric L.'s Avatar
Re: Re: Who sad cleaning throttle body dont help?
Fuel injector cleaner (the kind you pour into the gas tank) will not clean your throttle body. Fuel is injected downstream of the throttle body.
Old Oct 31, 2001 | 07:20 PM
190hpKiLLA's Avatar
Granny Driven
Re: Re: Re: Who sad cleaning throttle body dont help?
REALLY??????
I sad throttel body cleaner FOR fuel enjected cars(not fuel enjector cleaner!)
Old Nov 1, 2001 | 01:08 PM
98sterlingmist's Avatar
Did you clean behind the butterfly or just spray. I guess that you used a toothbrush to scrub with. Any other specifics?
C
Old Nov 1, 2001 | 01:49 PM
JdawgX's Avatar
You know that you can do a better job. Just buy a TB gasket and take it off to clean it. Then you can make sure to get it done right. It's not that much more work either.
Justin
Old Nov 1, 2001 | 02:19 PM
BRIGBOY's Avatar
You sure about sprayin stuff in while the car is runnin.
I skipped that part.
Old Nov 1, 2001 | 03:52 PM
costcowholesale's Avatar
can you take a pic of the "butterfly"? I don't know what you're talking about, I took the intake piping off, then I see a blocked hole with some shiny piece blocking the hole? Did I opened up the wrong spot? I got bad/low idle and the part I opened was 100% clean
Old Nov 1, 2001 | 03:58 PM
JdawgX's Avatar
That shiney part blocking the hole is the butterfly. If you have any more ???s let me know
Justin
Old Nov 1, 2001 | 04:13 PM
shane's Avatar
How can i tell if i need to clean the throttle body and the fuel injectors clean also.How often should this be done yearly/mileage thanks
Old Nov 1, 2001 | 04:24 PM
ny96max's Avatar
Im thinking about cleaning my TB this weekend. I may just remove the TB and polish/clean the whole thing out. Im goin down to Nissan and buying their cleaner for the job. Hope it works out! I guess ill have to buy another toothbrush too, lol
Old Nov 1, 2001 | 06:18 PM
190hpKiLLA's Avatar
Granny Driven
Yes its safe running the car without the intake. Good luck. I love the way it works after I cleaned it. Its allways clean before the throttle body, but when you open it and spray and scrub you will see how dirty that **** is. WARNING. Dont over spray you will have truouble starting your car. Refer to upper instaructions.
Old Nov 1, 2001 | 06:35 PM
"When you open it" as in when you open the intake piping or can you actually open the butterfly up? because mine was really clean but I got low idle
Old Nov 1, 2001 | 06:55 PM
190hpKiLLA's Avatar
Granny Driven
MAn I told you it looks clean but when you open it with ur hand by using the throttle cables. Its very dirty inside. I used Bounty I cleaned untill i could eat from it. Be carefull not to leave any paper towels in there OK!
Old Nov 1, 2001 | 11:32 PM
asianpr3082's Avatar
does anyone know how to take out the TB cuz when i look at it it looks like a b*tch to take out
Old Nov 2, 2001 | 03:43 AM
got rice?'s Avatar
I just have someone sit in the car with their foot on the accelerator pedal floored. This way I can use both hands to spray and scrub
Old Nov 2, 2001 | 06:10 AM
190hpKiLLA's Avatar
Granny Driven
Thats correct. Make sure the car is not ON when you are flooring it. If it is Bye Bye engine.
Old Nov 2, 2001 | 10:24 AM
ptatohed's Avatar
Licensed to Spell
You HAVE low idle.
Old Nov 2, 2001 | 10:27 AM
JdawgX's Avatar
Originally posted by ptatohed
You HAVE low idle.
Someone's a grammer ****!
Old Nov 2, 2001 | 11:15 PM
Stillen_I30's Avatar
why would it be bye bye engine if the car is on while flooring it and cleaning? i did this and my car is fine...the cleaner instructions even said to clean this way (as the primary method) and if the car would not remain on, then spray, reattach pipe, start, remove and clean again, repeating until done.
Old Nov 3, 2001 | 07:57 AM
got rice?'s Avatar
You HAVE low idle.
You got game?
Old Nov 3, 2001 | 11:33 PM
190hpKiLLA's Avatar
Granny Driven
U cant floor the the car when its not moving u could blow the engine. I hope I will never buy a car from you!
Old Nov 4, 2001 | 05:52 AM
sp6040's Avatar
Old Nov 4, 2001 | 07:40 AM
got rice?'s Avatar
that is what rev limiters are for
Old Nov 4, 2001 | 05:42 PM
You HAVE low idle.
sorry, I didn't pasT grEde tO grammEr
Old Nov 4, 2001 | 05:49 PM
mAdD MAX's Avatar
You won't blow the engine, but its not good for the engine either. There's no load to the engine and its revving to redline..I think a lot of fuel doesn't get burnt since the car's at WOT and the ecu is on OPEN-LOOP and fuel is just getting dumped in the cylinders and a lot of it doesn't get burnt and deposits are left in the cylinders.
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
97_GXE
Sep 15, 2015 06:47 AM
followthadollar
Sep 13, 2015 09:55 AM
Maxboy23
Sep 9, 2015 10:37 AM
