mixing oil
Old Apr 8, 2008 | 07:18 AM
Maximeltman's Avatar
mixing oil
Is mixing 5w30 with 10w30 ok to do? it's all synthetic mobile1...thanks
Old Apr 8, 2008 | 07:26 AM
udienow's Avatar
i dont c a problem... wouldnt it just make like 7w30?
searched for u:
http://forums.maxima.org/showthread....ght=oil+mixing
Seems like it doesnt matter
Old Apr 8, 2008 | 07:36 AM
97SMG's Avatar
^^ 7w30. 15w60 perhaps.....
Old Apr 8, 2008 | 07:47 AM
Kountz430's Avatar
bald aggression est 78
Thats funny^^^
Old Apr 8, 2008 | 01:40 PM
Snypa's Avatar
shud be fine.........i guess.
Old Apr 8, 2008 | 01:41 PM
99grnmaxgxe's Avatar
Originally Posted by Ammi
Don't worry about it. You can safely mix engine oil. Think of it this way; you blended the 2 characteristics of 2 different oils.
Old Apr 8, 2008 | 02:40 PM
VANGtastic97's Avatar
Originally Posted by Kountz430
Thats funny^^^
Woudn't the 5w-30 oil layer on top of the 10w-30 at cold temps?
Old Apr 8, 2008 | 03:07 PM
dgeesaman's Avatar
Maintenance Monster
Those oils are so close to the same thing it won't matter.
Old Apr 8, 2008 | 05:13 PM
thanks dudes
Old Apr 8, 2008 | 06:09 PM
slow97maxima's Avatar
member
Just curious, did you switch to 10 30? I remember someone telling me for higher milage to use 10 30... I now have 160k and I'm still using dino, but on the next oil change will switch to mobil 1 synthetic... Should I get 5 30 or 10 30?
Old Apr 8, 2008 | 06:17 PM
NmexMAX's Avatar
dot dot dot ...
It wont matter once the car is at operating temp. I'd say 5-30 for the winter 10-30 for the summer.
Old Apr 8, 2008 | 07:00 PM
exactly! you don't want to use 10-30 in NH winters.
Old Apr 8, 2008 | 09:42 PM
hot_wax_tree's Avatar
I just always use 5 30 cause it is not as thick.
I have always been warned on switching to synthetic to not do it because if you have a lot of miles on your car there are typically more cracks in line and whatnot so you would leak a lot of oil. but i dont know how true that is so dont quote me on that.
Old Apr 8, 2008 | 09:43 PM
kzoosho's Avatar
I run 20 50 woo for me.
Old Apr 8, 2008 | 09:48 PM
vqmaxman's Avatar
Mixing oils will damage and breakdown the oil chemicals and From what I have heard and read on some oil bottles and some manuals,If you mix up oil you can increase your chances of damaging your engine.
Old Apr 8, 2008 | 09:50 PM
Crusher103's Avatar
we run 10w 40 in the winter works just fine for us
Old Apr 8, 2008 | 09:58 PM
member
Well i know mobil 1 has a high mileage syntehic oil, i havent looked into it but i figured it was more or less a marketing gimmick. So with 160k what is recomended, stick with dino walmart oil or go to syntetic (regular or high mileage)
Why worry about engine sludge?
Old Apr 8, 2008 | 10:01 PM
Crusher103's Avatar
walmart uses Pennzoil, we had a old Ford and Pennzoil was that cars worse enemy, dont use that **** save Urself alot of headaches
Old Apr 8, 2008 | 10:03 PM
fergsmax's Avatar
fergujos
is there a benefit of mobil 1 compared to gtx?
Old Apr 8, 2008 | 10:29 PM
Crusher103's Avatar
no not really, they are both about equal till U get in to synthetics, mobil 1 synethetic is better than castrol.
Old Apr 8, 2008 | 10:31 PM
kzoosho's Avatar
And royal purple is the best of all. Thats all i run .
Old Apr 8, 2008 | 10:42 PM
Crusher103's Avatar
I dont think royal purple is really worth it, tryed it once worked great but its too expensive
Old Apr 8, 2008 | 10:45 PM
kzoosho's Avatar
Not that much more than mobile one. Plus i run all royal purple. Gear oil, water wetter and engine oil.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
