Red/Clear Issues
Old Apr 13, 2008 | 07:57 PM
  #41
castlemax's Avatar
It's kind of funny how the simplest mods can become the most complicated ones.
Old Apr 13, 2008 | 08:55 PM
  #42
ouzo99max's Avatar
10 amp worked.
im going to check the bulbs tomorrow
Old Apr 14, 2008 | 12:54 PM
  #43
JacksMax's Avatar
Theres really no way to describe this issue without using the word 'cluster' LOL
So, once you ever are able to tell an 1157 bulb from the others, you will see that theres two elements in there, the dim one is the one you call 'running lights', the ones that light when the lights are on, then the bright one will light with the brake pedal.
I'd put the old 7.5A fuse back in, turn on the lights and do a test with a voltmeter, then have someone press the brakes and test it then. You should see voltage to the dim side first, then to both on the second test. If not, trace the wires to see whats wrong. Maybe the two hot wires to the bulb got reversed?
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
wingnut2006
Sep 19, 2015 06:13 AM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
