Clutch issue
Old Apr 14, 2008 | 06:23 PM
jeostang's Avatar
Clutch issue
My clutch started slipping tonight. However I don't know if its the PP, or air in the system. I've been have to replace fluid about once a month. Should I just replace the clutch?
Old Apr 14, 2008 | 06:30 PM
kzoosho's Avatar
Does it slipp al the time? Are you sure you dint have your foot on the pedal at all? If you rest your foot there you can depress it and cause it to slip. I would deff look into your options before you swap a clutch .
Old Apr 14, 2008 | 06:52 PM
jeostang's Avatar
If I put it in 4th, and try to accelerate, (not even hard) it will slip. 5th is the same way, as well as third. It does it all the time.
I was hoping it was just air in the system.
Old Apr 14, 2008 | 07:01 PM
kzoosho's Avatar
That sounds like a clutch issue. How many miles on it?
Old Apr 14, 2008 | 07:03 PM
jeostang's Avatar
just hit 130000
Old Apr 14, 2008 | 07:17 PM
kzoosho's Avatar
i would deff throw a clutch in. Now question, do you plan to mod it at all?
Old Apr 14, 2008 | 08:42 PM
jeostang's Avatar
Not any more. THis is my wifes car now.
Old Apr 14, 2008 | 09:26 PM
kzoosho's Avatar
Well get you a 5th gen clutch man you be golden.
Old Apr 15, 2008 | 12:28 PM
jeostang's Avatar
Thanks for the help.
Where is the best place to pick one up? There also has to be a leak some where since I have to keep adding fluid.
Old Apr 15, 2008 | 12:31 PM
soccerplr19's Avatar
check your master/slave cylinder?
Old Apr 15, 2008 | 12:59 PM
deadmax96's Avatar
and your lines??
Old Apr 15, 2008 | 01:04 PM
jeostang's Avatar
Looks like its a rubber line. Are there any good online places to get all the parts I need.
I can't believe the machine shop near me wants to charge 100 bucks to resurface the flywheel.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
conansriver
Nov 18, 2015 02:46 PM
gustavison
Oct 4, 2015 06:50 PM
wingnut2006
Sep 19, 2015 06:13 AM
