1 step colder with the plugs?
Old Apr 15, 2008 | 07:28 AM
locklear's Avatar
Anyone ever go one step colder with the heat range on plugs on a bone stock VQ? Just curious if they would foul up
Old Apr 15, 2008 | 07:43 AM
There is absolutely no need to go with one step colder plugs on a stock VQ. Don't do it.
Old Apr 15, 2008 | 07:59 AM
locklear's Avatar
So.....they'll foul out then?
Old Apr 15, 2008 | 08:21 AM
mtrai760's Avatar
'Trynna' is not a word
No, but you will make less power, which will also have a negative, albeit slight, affect on your gas milage. Stick with stock.
Old Apr 15, 2008 | 08:35 AM
locklear's Avatar
Originally Posted by mtrai760
Stick with stock.
Will do.....thanks.
Have you tried ngk iridiums ix's? I've got them in my ca18det s12, and they do well.....and was thinking about putting them in the vq
Old Apr 15, 2008 | 08:40 AM
Will do.....thanks.
What exactly are you trying to accomplish by not using the NGK spark plug that is specified for your bone stock VQ??
Old Apr 15, 2008 | 09:02 AM
locklear's Avatar
With the IX's and stock "5" heat range......longevity mostly, maybe better fuel efficiency, maybe crisper throttle response.
With IX's and one step colder "6" heat range...my hopes were (and I know it's a bandaid), but I was wondering if it would take care of my engine ping, that I ONLY seem to get on hot summer days, which in turn throws the knock sensor code. But if the colder plug will cause other problems on a stock motor, then I don't want to go that route.
I've tried the ngk V-powers a long time ago, and wasn't impressed with them in the vq
Old Apr 15, 2008 | 09:14 AM
Have you tried to diagnose the cause of the pinging?? There are four major causes of pinging. Severe engine overheating, carbon buildup, malfunctioning EGR, and incorrect ignition timing.
I'd start by checking the EGR system, the cooling system and the ignition timing. And if none of those things fix it, then you'll have to consider using a higher-octane fuel (100 octane unleaded race gas),
that will drop your internal engine temps a little...
Have you pulled the spark plugs and looked for signs of carbon build-up? There could be excessive amounts of carbon buildup inside the cylinders and on the pistons thus raising the compression ratio and internal temps. The carbon is also known for retaining heat.
Old Apr 15, 2008 | 09:22 AM
Nealoc187's Avatar
SLOW
People really read too much into spark plugs and all the snake oil that spark plug companies feed them.
What exactly didn't you like about the regular NGK V-powers that you believe some other spark plug did better?
Old Apr 15, 2008 | 09:40 AM
locklear's Avatar
I actually pulled the plugs a couple of days ago, which are Denso iridiums, and have almost 60k miles on them, and was the first time I have pulled them since I put them in back in '03. I was suprised and happy to see that all 6 of them have a light grey "normal" appearence.
Cooling system is fine....needle has always stayed smack in the middle of the gauge....and has NEVER gone above. I am going to flush/ change the coolant before summer gets here, and kicking around the idea with maybe a 30/ 70 distilled water mix with Redline water wetter.
I've always used the highest avail octane pump gas....where I live now is 93, and back out in Cali was 91.
I'll check the timing today. How do I check the egr, and carbon build-up?
As far as the v-powers.....short life span
Old Apr 15, 2008 | 10:39 AM
Xzecution'R's Avatar
i never run platinums or iridums in my mx-6 tubro and my s12 which i don't have anymore. some boosted motors don't respond well to those plugs because they heat up and cause pre mature combustion which is probably why ur pinging in the summer. stick with regular ngk's and if anything i'd shorten up the gap a bit to prevent spark blow out.
Old Apr 15, 2008 | 10:57 AM
locklear's Avatar
My maxima is not boosted, so spark blow out shouldn't be an issue.....especially on a boner stock motor
gigabyte
Jan 6, 2017 06:05 PM
magiconthetire
Oct 26, 2015 09:03 PM
