Scary noise coming from my Max...
Old Nov 1, 2001 | 10:00 AM
jerzeeMax's Avatar
Just wondering if anyone else has experienced this before - When making sharp turns or turning onto an uphill driveway (slow or fast), I hear this click click clack noise that sounds like rods/bolts flexing. It's pretty loud and it sounds like its coming from right under the shifter/middle console. I thought it might have had something to do with the new y-pipe that I just installed but it fit pretty snug and it doesn't sound like a rattling noise that could be coming from something touching the pipe. Whats weird is that I get the exact same noise whenever I accelerate over 5k in second gear. Does this sound familiar to anyone? Any ideas would be appreciated. btw I'm an auto.
Old Nov 1, 2001 | 11:14 AM
njmaxseltd's Avatar
I wanted to say CV joints. But you say your hearing it in the middle sort of? Usually the CV joints on the outside go bad. Resulting in a click clack click clack noise when the wheel is turned and you step on the gas. I wonder if an inner joint would produce noise similar to what your hearing. I'd check the drive shafts, both ends and see if your CV boots are all ok.
Old Nov 1, 2001 | 11:55 AM
ny96max's Avatar
sounds to me like you have bad strut tower bearings!! mine did the same thing until i swapped them both out and solved my problem
Old Nov 1, 2001 | 01:20 PM
CHIGGARMAX's Avatar
I have the same problem.
How do you tell if you have bad CV joints?
ny96max,
what is strut tower bearings? where is it?
how much was part/labor?
Thanks,
Chiggarmax
Old Nov 1, 2001 | 06:58 PM
190hpKiLLA's Avatar
Granny Driven
Dope car
Ny96max you have a hot max!
pjgreek
Sep 9, 2015 09:30 PM
lux97Max
Sep 4, 2015 05:42 PM
jfl330
Sep 4, 2015 01:44 PM
Justin Kroll
Sep 2, 2015 11:06 AM
