odometer/trip quit
Old May 3, 2008 | 10:34 AM
sicivic89's Avatar
odometer/trip quit
So my odometer quits right as it was turning from 143999 over to 144000. The trip quit as well. I just took the cluster apart to look at it closely. Anyone know if I can take apart the speedo and try to fix it? Or is it just a lost cause? Anyone that can point me in the right direction would be must appreciated.
I did a search, but none of them tell if I can fix the cluster I have by doing some surgery on it.
Old May 3, 2008 | 03:58 PM
pmohr's Avatar
No more Maximas...
Does your speedo work?
You could try, but it really isn't worth it IMO. Just grab a used cluster with ~same amount of miles on it from the classifieds or a junkyard.
Old May 3, 2008 | 04:11 PM
sicivic89's Avatar
Yeah, the speedo works. I guess that might be my best option. But I was just curious if anyone had any experience with taking the odometer apart and got it working again.
Old May 4, 2008 | 10:05 AM
black_maxed95's Avatar
some people have said wd-40 or some other lubricant have fixed it. Mostly what happens is that it doesnt actually break, but it just gets stuck.
Old May 16, 2008 | 11:18 AM
LoSRx7's Avatar
I'm having the same issue, but the speedo not working also. It's intermediate. I'm hoping its a lose connection, going to check this afternoon.
It's fun driving trying to guess your speed
Old May 18, 2008 | 07:38 PM
maxprivate's Avatar
Black Lion
if its working intermittently then chances are the part is failing. get yourself a new speedo head from courtesy nissan and they will calibrate the mileage and send you the new part. you can install it yourself very easy to do. I had the same problem so i speak from experience.
Old Jun 15, 2008 | 06:17 PM
che_rokee's Avatar
I got the same problem when the speed sensor's harness broken. Speedometer started working intermittently and after 3 days dropped to zero. After fixing the harness (it is near the starter) speedo starts working.
But I still have the problem with odometer. It is not completely stuck, just rolling 10 times slower than could to. I have a neutral/park gage code (M/T) and no back-up lights. May be this is the case.
Unclejunebug
Apr 2, 2016 05:42 AM
msellas
Sep 23, 2015 09:16 PM
ajahearn
Sep 19, 2015 03:03 PM
followthadollar
Sep 17, 2015 06:31 PM
