Any MEVIs out there w/ NWP spacers yet?
Old May 30, 2008 | 03:02 PM
  #41
t6378tp's Avatar
Turbo 3.5
Originally Posted by NmexMAX
I have a dyno.
basically a loss of 8 - 12 ft /lbs from 3500 - 4500, then a gain of typically 40+whp @ 6550.
not that dyno, I have my own
I am talking about a mevi/nwp spacer dyno
Old May 30, 2008 | 03:04 PM
  #42
t6378tp's Avatar
Turbo 3.5
Originally Posted by mowgli29
is it actually thick enough to fit a nozzle in?
from past convo's with arron, yes it is
Old May 30, 2008 | 03:09 PM
  #43
NmexMAX's Avatar
dot dot dot ...
Oh shatzicles.
Old May 30, 2008 | 03:56 PM
  #44
xHypex's Avatar
Originally Posted by Flava_24/7
Wow, talk about a thing from the past. You still here in Austin and have the Max?
I moved back from Austin to Dallas last June, and I still have my Maxima (only 112k on the clock). I've been lazy but I still need to sell my NOS 5124 kit; althought it seems the 5124 has fallen out of favor with users here.
Regarding the spacers are the gains primarilly from reducing heat soak of the intake manifold, or does it also have to do with increasing the length/velocity of the intake airflow?
-hype
Old May 30, 2008 | 04:09 PM
  #45
NmexMAX's Avatar
dot dot dot ...
-hype
Seems to be a combination of both. On the 5.5 gen, it defiantely sounds better, even w/ a stock airbox.
Old May 30, 2008 | 04:22 PM
  #46
xHypex's Avatar
Unfortunately, sounding better and adding power can often be mutually exclusive outcomes.
The reason I asked is that as I recall, the MEVI works because the butterflies effectively make the piping act like longer runners than the stock intake manifold. I'm wondering if using the spacers will cause another drop on the low end and add back on the top end.
-hype
Old May 31, 2008 | 12:02 PM
  #47
Aaron92SE's Avatar
NWP Engineering.com
Originally Posted by t6378tp
btw arron if you ever start offering just the tb spacer please let me know, I want to tap it for a nitrous nozzle
Will do. But I doubt I will ever start making a 1" thick TB spacer. Until I can prove the gains, I can't comment on the performance increase. Most aluminum TB spacers I've seen are not worth the money.
The TB spacers we offer are made of a high quality phenolic laminate and is only a 1/4" thick. You won't be able to tap a nitrous nozzle in a 1/4" thick spacer.
Are you referring to the 1/4" phenolic TB spacer?
-hype
As NmexMAX said, it's a combination of both. You will still get noticeable results simply by lengthening the intake runners. But by just doing that and nothing else, you will lose top end performance since you are shifting the torque band. But since you eliminate the stock poorly sized OEM gaskets and actually improve the airflow from one manifold to another, top end power isn't decreased. Also, the extreme intake manifold temperature decrease prevents heat soak power loss when you are hotlapping at the track or stuck in traffic in the summer.
-hype
You may be thinking about it backwards. The longer the intake runners, the more low end power you'll make while sacrificing top end performance. The shorter the runners, the less low end power with more top end.
Old May 31, 2008 | 09:28 PM
  #48
t6378tp's Avatar
Turbo 3.5
thanks for the post, there is nothing like hearing it 1st hand
litch
123
Jan 4, 2024 07:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
lrb6805
Sep 30, 2015 08:12 AM
Maxboy23
Sep 4, 2015 06:04 PM
