120K and a different sort of problem
Old May 12, 2008 | 09:23 PM
kcryan's Avatar
So my 98 I30 is nearing in on 120k, auto VLSD. And its been doing this for a while, but has gotten worse recently. It always seems to idle a little low (700 ish) but when i go to slow down and get near stopping, or just start it up after its been sitting for a while, its rpms will drop to 500 or below, and it will just then catch itself, and jump over 1000k, but im afraid that if this gets even slightly worse, it will likely start stalling.
Any thoughts, its all stock minus Cattman muffler, and a few small electric things inside.
Old May 13, 2008 | 07:28 AM
shorterchild's Avatar
I've been starting to notice the same sort of problems in my '95 GXE. Tell me, have you noticed any hard starts, jerky acceleration, or sputtering exhaust? It could be your one or more of your spark plugs has gone bad, or worse one or more of your coil packs has gone bad.
The fix might also be as simple as cleaning your throttle body, or installing a new throttle position sensor.
bt dubs: I changed the MAF a few months ago to fix a bucking/stalling problem. It wasn't until put in the new MAF that I noticed a sputtering exhaust. Changed 2 coil packs, front O2 sensors, engine coolant temp. sensor, TPS, cleaned TB, and put in new spark plugs. May have been overkill, but all of that fixed the bad idle and hard starts, and now my '95 Mimi gets 23 mpg.
Old May 13, 2008 | 08:11 AM
shadyonedeath's Avatar
try grounding your maf. Search "grounding maf"
Old May 13, 2008 | 08:39 PM
NISSANMAXIMA91's Avatar
Clean the IACV
Old May 13, 2008 | 08:50 PM
khantalha+'s Avatar
^^^^^... i would clean iacv first....
Old May 14, 2008 | 11:42 AM
NissanSE98's Avatar
clean the iacv....
but i was having problems like this too.....had a leaky hose....
-- look for some air leaks
---- also, i heard as a trick...
when searching for a leak, spray some WD40 around the hoses/gaskets and if the engine revs up then you've found your leak .....as in the WD40 is combustible and would burn off/increase rpm's when it hit the leaky section
--some "older" mechanics were doing it while working on a motocycle
-- i guess it's no worse than having the dirty air leak in and as long as it's not excessive...should be fine
Old May 14, 2008 | 06:20 PM
kcryan's Avatar
Cleaned the iacv, not perfect, but its slightly better, will look for leaks.
Thanks gents
Old May 15, 2008 | 09:41 AM
clint240sx's Avatar
The fix might also be as simple as cleaning your throttle body, or installing a new throttle position sensor..
i am getting all those problems except for the sputtering exhaust. i have 117k on my 99 maxima...
9aj9
Apr 5, 2020 12:11 AM
jsmith24
Feb 1, 2016 12:35 AM
msellas
Sep 23, 2015 09:16 PM
ajahearn
Sep 19, 2015 03:03 PM
thenewguyy
Sep 12, 2015 11:12 AM
