Tranny Guys step in!
Old May 18, 2008 | 12:24 PM
Blackwind's Avatar
Car- 98 se 5spd
Trans- 2000 open diff
Problem- grinding when turning and accelerating which is also speed related.
Diagnoses- jacked car off the ground, removed the wlees, started car and neither wheel would spin. Placed the car in 1st gear passenger wheel would spin and skip on occasion, turned the wheel while in first would completly stop spinning and grinding would start, then it would skip more. Did not see the driver side while testing.
thoughts?
Old May 18, 2008 | 12:37 PM
pmohr's Avatar
No more Maximas...
Grinding sound like syncro clash?
Check to ensure that the axles are fully seated into the diff, first thing.
Old May 18, 2008 | 01:02 PM
njmaxseltd's Avatar
If the grinding sound happens when you turn the wheels while they are off the ground spinning, then you have an axle problem, not a tranny issue.
Old May 18, 2008 | 01:06 PM
Blackwind's Avatar
but wouldnt one wheel still spinn in nuetral or is that just on lsd transmissions?
Old May 18, 2008 | 01:08 PM
Blackwind's Avatar
no not the synchro clash. the grinding happens in gear and in nuetral. and the axles are all the way in.
Old May 18, 2008 | 01:13 PM
pmohr's Avatar
No more Maximas...
Might, might not. They're only spinning from internal drag.
Old May 18, 2008 | 04:06 PM
S1cTech's Avatar
I am not as great as pmohr is with transmissions but I was thinking of an axle issue as well... Syncho clash makes sense...
Old May 18, 2008 | 05:25 PM
Blackwind's Avatar
so i hit the road today. when i accel the grinding increases with speed then when i shift (clutch in) it goes away and then comes right back when i engage the gear. it comes and goes now. i thought axles too but i just replaced the drivers side with one from raxels so that didnt do it. ill replace the passenger side next to see if that does it.
has anyone had a problem like this?
Old May 18, 2008 | 10:19 PM
Blackwind's Avatar
gotta bump, need the help.
Old May 19, 2008 | 02:01 AM
dgeesaman's Avatar
Maintenance Monster
With the wheels off the ground, does turning one wheel result in the other wheel turning smoothly and free of noise?
Can you get someone to drive it with the wheels lifted and put your hand on the tranny? I would expect you could feel the vibration if it's internal to the tranny and bad enough to be audible.
I suggest you change the gear oil, too, since what's in the gear oil will tell you a lot about what's going on in the tranny.
dave
Old May 19, 2008 | 02:07 AM
Big_E-Dog's Avatar
2nd Gen Boostinator
if it goes away when your clutch is in then its either the throw out bearing or selector fork platic bushings are work causing the selector disk to grind o the fork, never heard of it hapening but youll never know until you either take it apart or to a tranny shop.
Old May 19, 2008 | 07:58 PM
Blackwind's Avatar
ill get back to you.
Old May 19, 2008 | 08:00 PM
Blackwind's Avatar
dave
whats strange to me is that it grinds like twisting metal even if my foot is not on the clutch. i can coast and make a turn and it sounds like the APC from aliens!
A32goldylocks
Sep 2, 2015 06:39 AM
Lowered_a33
Sep 1, 2015 07:49 PM
max1029
Aug 26, 2015 09:51 AM
maxipower
Aug 21, 2015 11:10 AM
mikekay
Aug 10, 2015 12:52 PM
