How Do The Fogs Pop Off?
Old May 25, 2008 | 10:50 AM
Eyce's Avatar
I have a 96 SE Max, and I'm having a hard time getting the fog lights off.
Can anyone explain how exactly they are removed so I can install my new bulbs?
Old May 25, 2008 | 11:49 AM
Eyce's Avatar
btw i checked the manual, it said "Push Up"
so i did. nothing happened.....
Old May 25, 2008 | 11:58 AM
maxilac99's Avatar
if they are similar to the 98-99's then there are 2 screws that you have to take out. check behind the bumper cover.
Old May 25, 2008 | 12:02 PM
ptatohed's Avatar
Licensed to Spell
Haynes, Chiltons, FSM, search...
Old May 25, 2008 | 12:03 PM
Eyce's Avatar
^ I don't have a clue what that means,
the manual suggests poping off the side part of the light by "pushing up" and then there's a screw below it for the actual fog lamp itself...
this makes no sense to me. I pushed up like mad.
Old May 25, 2008 | 12:05 PM
arrocha87's Avatar
i was wondering the same thing... dont u have to remove he bumper cover? because the screws are behind it.
Old May 25, 2008 | 12:07 PM
Eyce's Avatar
i sure as hell hope not....it shouldn't be that hard....
Old May 25, 2008 | 12:25 PM
arrocha87's Avatar
well if you see my profile pic youll see im missing my passenger fog. i bought one like 6 weeks ago at the pick and pull and im still wondering how to put it on... cause u can put it in there but how the hell do we put the screws on? anyone got a link to a thread?
Old May 25, 2008 | 01:36 PM
Eyce's Avatar
Yeah, I think you may have to take the cover off after looking at it and trying everything from the front...bahhh
Old May 25, 2008 | 02:41 PM
j2b4osan's Avatar
the small glass section towards the center of the car must be removed to expose the screws. to remove you have to push in and up on the top (this is sometimes very hard to do, you can try sticking a screwdriver with cloth covering it and pry from the bottom but be careful not to break the piece) than there are two screws you must remove and than you pull the other part of the light out. be careful and keep trying and you'll figure it out.
Old May 25, 2008 | 02:46 PM
submaxzero's Avatar
PM me ill try to help i own a 98 but i think i can help dude
Old May 25, 2008 | 04:29 PM
Snypa's Avatar
its not the same as 97-99. I somehow think that based on how they look, the bumper cover has to come off or either some screws are to be loosen somewhow behind the bumper cover. The lights are "flush" with the bumpoer cover, so there arent any screw are there like the 99's.
Old May 25, 2008 | 05:16 PM
nafddur's Avatar
FSM (section BF, page 6) shows how the fog lights come out. You DEFINITELY don't have to remove the bumper cover. Christ, even US car designers wouldn't have been THAT retarded.
I've done several fog lamp bulbs on my 95 SE over the past 13 1/2 years, and it's really very easy.
Press in and push up on the small, unlighted, plastic part of the light assembly and this part will pop off exposing one bolt that holds the rest of the light in. With this bolt out, pry the light assembly towards the center of the car to free up the 2, support clips on the outboard side of the light (I don't know how else to describe these clips - once you see them you'll see how simply they work).
You might need to pry the plastic part that covers the one bolt up with a screwdriver, but be careful - it and the clip that holds it in place are only flimsy plastic.
Once you know how to do it, replacing a fog lamp bulb is a 5 minute job.
Good luck.
Old May 25, 2008 | 05:49 PM
arrocha87's Avatar
imma go outside and try rite now... brb
Old May 25, 2008 | 06:02 PM
arrocha87's Avatar
ok i took it off. how do i clean the inside of the rust stain or watever it is?
Old May 25, 2008 | 06:08 PM
arrocha87's Avatar
Old May 25, 2008 | 06:10 PM
Crusher103's Avatar
^^damn did someone **** in Ur fogs?
Old May 25, 2008 | 07:33 PM
arrocha87's Avatar
LOL. idk what happnd it probably sat wih water in it at the pick and pull. thats the one i bought, but hey i only paid $5 for it. my drivers side i just took off is perfectly clean, just cracked from gravel hitn it.
Old May 25, 2008 | 09:31 PM
QNO_A32's Avatar
where did you find that fog light in the woods? it has a hole in it somewhere and you will need another one.
Old May 25, 2008 | 09:58 PM
max95q's Avatar
Youre going to have to heat them up and open it up. The fogs are the hardest to open. And I mean hard. Ive done it twice to the same ones and both times it was hell. These make the headlights and all the other lights Ive opened up feel like a damn toy. I think they use a different glue/sealer. Ive even cracked my housing doing it too. Good Luck!
Old May 25, 2008 | 10:08 PM
arrocha87's Avatar
oh damn... what if i pour some clr in it? or will that make it worse?
Old May 26, 2008 | 06:57 AM
Eyce's Avatar
Good luck.
Thanks for the help, hopefully I can get it to work!
Old May 26, 2008 | 09:28 AM
Snypa's Avatar
$$chi ching ching$$ !!!
Old May 26, 2008 | 01:55 PM
arrocha87's Avatar
oooh damn.. idk bout opening them.... wat bout clr? any1 got any input on that or will it damge the chrome reflector part? ima try i only paid $5 for it anyways! :-)
Old May 27, 2008 | 12:09 AM
CMax03's Avatar
I know on my 5th gen, it was cheaper and less time consuming to purchase the foglight kit than to buy the replacement lense! ABC Nissan (wholesale prices to the public)!
Mahmuth
Aug 16, 2024 08:23 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
