cutting bump stops
Old Nov 3, 2001 | 01:07 PM
DhaMax's Avatar
cutting bump stops
woohoo. I m ready for installation, i bought my struts from cattman, and their boots/bumpstops(one piece).
My question is that:
do i need to cut the bumpstops, since i m lowering the car to prevent my struts from bottoming out?
I m still confused on how the suspension bottoms out, or what it means, any one willing to explain? pwease
thanks
Old Nov 3, 2001 | 04:07 PM
ny96max's Avatar
sounds like a dumb-a$$ newbie question, but what are the bump stops?? where are they?
Ant
Old Nov 3, 2001 | 04:16 PM
Ryan93SE's Avatar
what kind of struts are they?.... I cut the bumpstops on my car when i put the toks on....but mine were factory bumpstops..... i would cut them but i think it would still be okay if you dont....
nymaxse....they are the rubber things that keep your struts from bottoming out
Old Nov 3, 2001 | 08:46 PM
Nismo's Avatar
cut them in half or so. Im lowered 1.6 inches and I only cut off 1 ring from the bump stops. I have about an inch and a half until it botoms out but its not a problem so far.
Old Nov 4, 2001 | 02:06 PM
DhaMax's Avatar
my struts are kyb agx's and b+g springs (1.6" drop), the bump stops i got are not factory, they are from cattman, and they are attached to the strut boot.
has anyone installed kyb agx's with cattman boots yet??? If so are we suppose to cut them?
Old Nov 4, 2001 | 02:22 PM
seouljah's Avatar
is bump stops the upper strut mounts? the kind with two versions one for lowered vehicles and stock
if so when did you purpose it? lady i talked to from cattman said they dont make em
Old Nov 4, 2001 | 02:54 PM
DhaMax's Avatar
Those are strut/spring covers goes on top of the springs, has the 3 bolts welded to them.
bump stops go on the strut rod, its just a little rubber piece, that prevents the shock from bottoming out. When i bought my agx's the lady said nothing about these, but i asked for them and she said it should work.
The only reason for me questioning the cutting of them is because i am lowering the car.
Old Nov 4, 2001 | 03:00 PM
njmaxseltd's Avatar
Yes, I've installed them, don't cut the bump stops, you should be fine.
D Mason
Jun 21, 2016 04:43 AM
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
Need help
23
Oct 2, 2015 08:56 AM
